Question
argo
Question
PostPosted: Wed May 11, 2016 1:51 pm     Reply with quote
Hi all
I would like to know if this code uses (is based) "timer interrupts"?
Thank you in advance!
#include<12f683.h>
#fuses INTRC_IO,NOWDT,PUT,NOPROTECT,NOMCLR,NOBROWNOUT
#use delay(CLOCK=8000000)  //8MHz
#byte  GP=5
 #bit IRSIG=GP.3
#define ON 1
#define OFF 0
#define HI 1
#define LOW 0
#define el_on 0x31
#define el_off 0x0e
#define rd_on 0x02
#define rd_off 0x35
signed long th_count,rd_count,el_count;
signed long rev_mix,rd_duty,al_count,rd_trim;
int cycl_count,el_duty;
byte gp_now;
// PWM
#int_rtcc
void soft_pwm()
  set_timer0(156);
  if(cycl_count < rd_duty){   // ON
    gp_now=gp_now | rd_on;
    GP=gp_now;
  else{   // OFF
    gp_now=gp_now & rd_off;
    GP=gp_now;
  if(cycl_count < el_duty){  // ON
    gp_now=gp_now | el_on;
    GP=gp_now;
  else{   // OFF
    gp_now=gp_now & el_off;
    GP=gp_now;
  cycl_count++;
  cycl_count %=99;
main(){
  int gcount;
  setup_oscillator(OSC_8MHz);
  setup_comparator(NC_NC);
  setup_ccp1(CCP_PWM);
  setup_adc_ports(NO_ANALOGS);
  setup_timer_0(RTCC_INTERNAL | RTCC_DIV_4);
  set_timer0(246);
       //0.5us*4*(255-246+1)=0.00002s(=0.02ms)
  setup_timer_2(T2_DIV_BY_4,255,1);
  enable_interrupts(INT_RTCC);     // Timer0
  set_tris_a(0x08);  // GP3
/*  GP   5   4   3   2   1   0
        el3 el2  SG  MTR MTT el1
         0   0   1   0   0   0
  cycl_count=rd_duty=el_duty=0;
  th_count=0;
  rd_trim=0;
  gp_now=OFF;
  while(1){
    gcount=0;
    while(gcount < 30){
       if(IRSIG==HI){
         delay_us(100);
         gcount++;
       else{
         gcount=0;
    While(IRSIG==HI){
//**************** Timer0 ******************
    disable_interrupts(INT_RTCC);
// 1ch
    al_count=0;
    while(IRSIG==LOW){ // Low
      delay_us(6);
      al_count=al_count+1;
    while(IRSIG==HI){
      delay_us(6);
// 2ch
    el_count=0;
    while(IRSIG==LOW){
      delay_us(6);
      el_count=el_count+1;
    while(IRSIG==HI){
      delay_us(6);
// 3ch
    th_count=0;
    while(IRSIG==LOW){
      delay_us(6);
      th_count=th_count+1;
    while(IRSIG==HI){
      delay_us(6);
// 4ch
    rd_count=0;
    while(IRSIG==LOW){
      delay_us(6);
      rd_count=rd_count+1;
    while(IRSIG==HI){
      delay_us(6);
//************** Timer0 ******************
    if(al_count > 180){
      rd_trim=rd_trim+2;
    if(al_count < 130){
      rd_trim=rd_trim-2;
    if(el_count<105){
      el_count=100;
    if(el_count>180){
      el_count=205;
    if(el_count > 160){
      el_duty=(el_count-155)*2;
    else{
      el_duty=0;
    rev_mix=th_count;
    if(th_count<110){
      th_count=0;
    else if(th_count>190){
      th_count=1023;
    else{
      th_count=(th_count-100)*10;     }
    set_pwm1_duty(th_count);
    rev_mix=rev_mix-100;
    if(rd_count<110){
      rd_count=100;
    if(rd_count>200){
      rd_count=200;
    if(150 <= rd_count && rd_count <=160){
      rd_count=155;
    if(rev_mix < 45){
      rd_duty=rev_mix+(rd_count-155)+rd_trim;
    else{
      rd_duty=rev_mix/10*7+14+(rd_count-155)+rd_trim;
PostPosted: Wed May 11, 2016 1:53 pm     Reply with quote
Yes.
#int_rtcc
This defines the timer0 (rtcc) interrupt handler.
argo
PostPosted: Wed May 11, 2016 2:35 pm     Reply with quote
Thanks for the reply, Ttelmah.
