johnl
| 16F1764 PWM5 not working |
Posted: Wed May 04, 2016 9:44 pm |
Pin C3 toggles as it's supposed to, but there's no PWM output on pin C2 (or any other pin.). PCM V. 5.055
| Code: | #include <16f1764.h>
#include <stdlib.h>
#fuses INTRC_IO,NOWDT, PUT, MCLR, NOPROTECT,NOBROWNOUT, NODEBUG, NOLVP
#fuses NOPPS1WAY
#use delay(INTERNAL = 32000000)
#PIN_SELECT PWM5=PIN_C2 //select the PWM 5 pin
{ set_tris_c(0);
port_a_pullups(0b1011);
set_tris_a(0b1011);
setup_pwm5(PWM_STANDARD | PWM_CLK_FOSC | PWM_CLK_DIV_BY_1);
set_pwm5_period(0x3FFF);
set_pwm5_duty(0x1FFF);
output_toggle(PIN_C3); //chip is alive. Instruction clock = 8 MHz
delay_us(125);
johnl
johnl
Posted: Thu May 05, 2016 5:22 pm |
Does the C code look like it should work?
If so, and it's not my hardware which only contains a 0.1uF bypass cap and a programming header, could this be compiler bug?
Here's the asm file (minus the includes):
| Code: | .................... #fuses INTRC_IO,NOWDT, PUT, MCLR, NOPROTECT,NOBROWNOUT, NODEBUG, NOLVP
.................... #fuses NOPPS1WAY
.................... #use delay(INTERNAL = 32000000)
0003: MOVLW 02
0004: SUBWF 26,F
0005: BTFSS 03.0
0006: GOTO 014
0007: MOVLW 20
0008: MOVWF 05
0009: MOVLW 06
000A: MOVWF 04
000B: MOVF 00,W
000C: BTFSC 03.2
000D: GOTO 014
000E: GOTO 012
000F: GOTO 010
0010: GOTO 011
0011: NOP
0012: DECFSZ 00,F
0013: GOTO 00F
0014: MOVLP 00
0015: GOTO 05B (RETURN)
.................... #PIN_SELECT PWM5=PIN_C2 //select the PWM 5 pin
.................... void main(void)
0016: MOVLW 55
0017: MOVLB 1C
0018: MOVWF 0F
0019: MOVLW AA
001A: MOVWF 0F
001B: BCF 0F.0
001C: MOVLW 10
001D: MOVLB 1D
001E: MOVWF 22
001F: MOVLW 55
0020: MOVLB 1C
0021: MOVWF 0F
0022: MOVLW AA
0023: MOVWF 0F
0024: BSF 0F.0
0025: MOVLW F0
0026: MOVLB 01
0027: MOVWF 19
0028: MOVLB 03
0029: CLRF 0C
002A: CLRF 0E
002B: MOVLB 02
002C: CLRF 12
002D: CLRF 13
002E: CLRF 11
002F: MOVLW 04
0030: MOVWF 10
0031: MOVLB 00
0032: CLRF 20
0033: CLRF 21
.................... { set_tris_c(0);
0034: MOVLW 00
0035: MOVLB 01
0036: MOVWF 0E
.................... port_a_pullups(0b1011);
0037: MOVLW 0B
0038: MOVLB 04
0039: MOVWF 0C
003A: MOVLB 01
003B: BCF 15.7
.................... set_tris_a(0b1011);
003C: MOVWF 0C
.................... setup_pwm5(PWM_STANDARD | PWM_CLK_FOSC | PWM_CLK_DIV_BY_1);
003D: MOVLB 1B
003E: BCF 1B.7
003F: MOVLB 01
0040: BCF 0E.2
0041: MOVLB 1B
0042: CLRF 20
0043: CLRF 5F
0044: CLRF 5C
0045: CLRF 1E
0046: MOVLW 80
0047: MOVWF 1B
.................... set_pwm5_period(0x3FFF);
0048: MOVLW 3F
0049: MOVWF 16
004A: MOVLW FF
004B: MOVWF 15
004C: BSF 1F.7
.................... set_pwm5_duty(0x1FFF);
004D: MOVLW 1F
004E: MOVWF 14
004F: MOVLW FF
0050: MOVWF 13
0051: BSF 1F.7
.................... while(TRUE)
.................... output_toggle(PIN_C3); //chip is alive. Instruction clock = 8 MHz
0052: MOVLB 01
0053: BCF 0E.3
0054: MOVLW 08
0055: MOVLB 02
0056: XORWF 0E,F
.................... delay_us(125);
0057: MOVLW 7D
0058: MOVLB 00
0059: MOVWF 26
005A: GOTO 003
005B: MOVLB 1B
005C: GOTO 052
005D: SLEEP
Configuration Fuses:
Word 1: 39C4 INTRC_IO NOWDT PUT MCLR NOPROTECT NOBROWNOUT NOCLKOUT IESO FCMEN
Word 2: 1EFB NOWRT NOPPS1WAY ZCDDIS NOPLLEN STVREN BORV19 NOLPBOR NODEBUG NOLVP |
Posted: Thu May 05, 2016 6:20 pm |
| Quote: |
#fuses NOPPS1WAY
You have MCLR enabled. You need an MCLR pull-up resistor. |
johnl
Posted: Thu May 05, 2016 6:31 pm |
| PCM programmer wrote: | | Quote: |
#fuses NOPPS1WAY
The data sheet says that when the config bit enables MCLR, then the PU resistor is enabled. Besides the chip is running, so it's not in the reset state. |
Posted: Thu May 05, 2016 7:19 pm |
You're right. You pointed that out to me in the previous thread.
I notice you're not setting the Phase register. What happens if you set
it to some small value ? |
johnl
Posted: Thu May 05, 2016 8:01 pm |
Wow...Good call!
I tried it with two chips on two boards and it worked both times.
Thanks!
| Code: | | set_pwm5_phase (32); |
johnl
Posted: Thu May 05, 2016 8:02 pm |
| Does this qualify as a compiler bug? |
Posted: Thu May 05, 2016 9:05 pm |
I don't think so. The PIC data sheet shows that the Phase register must
be set to something in the timing diagram for Standard 16-bit pwm mode. |
