Question about "X = (X > 200) ? 199 :Y ;"
nailuy
PostPosted: Sat Apr 30, 2016 5:39 am     Reply with quote
Hy
I found on net this paragraph:
static unsigned int8 X;
static unsigned int8 Y;
I modified to work on CCS.
My questions are:
#1.Can some explain to me how is working this code?
#2.Is faster than: "if(X>200){X=199;}"?
#3.X must be the same as Y?
I tested with:
X = (X > 200) ? 199 :0;
and do the same work.
Thank you in advance.
PostPosted: Sat Apr 30, 2016 7:35 am     Reply with quote
This is standard C. Every C textbook will have it. It's called a 'conditional expression'
You shouldn't have to change it to work with CCS, it'll work as it is.
The statement (test)?expr1:expr2
Evaluates 'test'. If test is true, it returns expr1, if not, it returns expr2.
In some cases, it can be done slightly smaller/faster than an 'if, since there only has to be one set of code to 'write' to the target variable.
So in your example, if x is > 200, the code returns 199, otherwise it returns Y.
This return is then put into X.
The actual syntax used seems slightly 'odd'. I'd have expected (for example), as a way of limiting a return value to 199:
    x=(y>200)?199:Y;
X will then get set to Y, if Y is less than 200, or 199 otherwise.
Key difference to your #2 code, is it does not change what is in the variable being tested. This may matter, depending on what the code is doing....
amcasi
PostPosted: Mon Dec 17, 2018 8:45 am     Reply with quote
Many many thanks for answering.
