PWM frequency falls in 4 times after sleep.
40inD
PostPosted: Wed Apr 20, 2016 1:44 am     Reply with quote
Why PWM frequency falls in 4 times after sleep instruction (at the end of code)?
When I comment these strings frequency does not change.
#include <12F1501.h>
#device ADC=8
#FUSES WDT                      //Watch Dog Timer
#use delay(internal=8000000)
#define RAND_MAX  255
#INCLUDE <STDLIB.H>
int16 pause , delay_sec;
int d1, d2, d3, d4;
int work_counter=1;
   setup_wdt(WDT_16S);      //~16,0 s reset
   setup_adc_ports(sAN1);
   setup_adc(ADC_CLOCK_DIV_64);
   setup_timer_2(T2_DIV_BY_64,63,16);  // 5kHz 8bit PWM @ 8MHz    (0-255)
   setup_PWM1(PWM_enabled|PWM_OUTPUT);
   setup_PWM2(PWM_enabled|PWM_OUTPUT);
   setup_PWM3(PWM_enabled|PWM_OUTPUT);
   setup_PWM4(PWM_enabled|PWM_OUTPUT);
   set_adc_channel(1);
   srand(142);
      delay_ms(1);
      pause=read_adc();
      srand(work_counter);
      d1=rand();
      d2=rand();
      d3=rand();
      d4=rand();
      delay_sec=rand();            // ãåíåðèðóåì ñëó÷àéíîå âðåìÿ ðàáîòû ìîòîðîâ îò 0 äî 255 ñåê
      set_PWM1_Duty(d1);
      set_PWM2_Duty(d2);
      set_PWM3_Duty(d3);
      set_PWM4_Duty(d4);
      for (int a=0; a<delay_sec;a++) // èñïîëíÿåì ñëó÷àéíîå âðåìÿ ðàáîòû ìîòîðîâ îò 0 äî 255 ñåê ñ ðåñòàðòîì âà÷äîãà
      {restart_wdt();
      set_PWM1_Duty(0); //off
      set_PWM2_Duty(0); //off
      set_PWM3_Duty(0); //off
      set_PWM4_Duty(0); //off
     // setup_PWM1(PWM_disabled);
     // setup_PWM2(PWM_disabled);
     // setup_PWM3(PWM_disabled);
     // setup_PWM4(PWM_disabled);
      restart_wdt();
      for (int i=0; i<pause; i++) //óõîäèì â sleep íà âðåìÿ time*16 sec
      sleep();
      work_counter++;
PostPosted: Wed Apr 20, 2016 2:39 am     Reply with quote
Clipped code section, comments inline:
      //restart_wdt(); - sleep automatically restarts the WDT
         sleep();
         delay_cycles(1); //sleep, should always be followed by a NOP
         //Not having this can cause slight problems if things like an
         //interrupt triggers a wake - safer to have it.
      setup_oscillator(OSC_NORMAL | OSC_8MHZ);
      work_counter++;
If you look at the 'sleep' entry in the data sheet, the first thing done when entering sleep, is to clear the WDT, so you don't need to restart the wdt before calling this.
The oscillator 'wakes' in a default mode. On the boot, the compiler automatically sets it up to your requested 8MHz. After sleep it is back to the default mode, so you need to reset it.
40inD
PostPosted: Wed May 25, 2016 11:58 pm     Reply with quote
I have one more problem.
The real PWM frequency is 488 HZ. But timer2 is configured for 5kHz (as says PICWizard). See code above.
I think it's wrong.
PostPosted: Thu May 26, 2016 1:25 am     Reply with quote
Forget wizards....
8MHz.
Fcy = 2MHz
/64 = 31250Hz
/64 (PR2=63 -> /64) = 488.28125Hz.
For 5KHz, you need Fcy/400
setup_timer_2(T2_DIV_BY_8,49,16); (50*8=400)
Which would give 0-199 for the PWM range
Or using the same divider
setup_timer_2(T2_DIV_BY_8,63,16);
Which would give 3906.25Hz.
However I've just gone and used the wizard for this chip, and it does not give 5KHz for the settings you have (It give 1952Hz). So it is forgetting the initial /4 built into the chip, but doesn't give your figure....
It only gives 5KHz for your settings, if you have not changed the master clock figure from the default 20MHz.
So, fault in it (*4), and fault in your settings (*2.5). GIGO.
