How to create accurate time in the CCS for PIC
hoa35ktxd
PostPosted: Sat Apr 16, 2016 7:55 am     Reply with quote
My code:
#include <16F883.h>
#FUSES WDT                      //Watch Dog Timer
#FUSES HS
#use delay(crystal=20000000)
int16 time_stick;
#INT_RTCC
void  RTCC_isr(void)
   set_timer0(5);
   time_stick++;
   setup_wdt(WDT_ON);
   setup_wdt(WDT_18MS|WDT_TIMES_128);      //~2,3 s reset
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1|RTCC_8_bit);      //51,2 us overflow
   enable_interrupts(INT_RTCC);
      restart_wdt();
      if (time_stick>=10000)
         output_toggle(PIN_A1);
         time_stick=time_stick%10000;
It runs slower than actual.
PostPosted: Sat Apr 16, 2016 10:03 am     Reply with quote
It's right there in the Code Library, near the top:
http://www.ccsinfo.com/forum/viewtopic.php?t=26177
PostPosted: Sat Apr 16, 2016 11:25 am     Reply with quote
PCM P is right !! I've used this code on 4 different PICs and it's bang on !!
on the plus side, no I/O pins used !!
Though for any 'serious' timekeeping it's best to use an RTC chip like the DS1307 with coin cell battery unless your PIC power supply IS battery backed up.
hoa35ktxd
PostPosted: Sun Apr 17, 2016 1:47 am     Reply with quote
Many thank!
asmboy
PostPosted: Sun Apr 17, 2016 8:49 pm     Reply with quote
I read this and wonder: How many seconds / year (+/-) of absolute error is "accurate"???
There is a big difference if we are talking astronomy or navigation vs. a personal alarm clock...
PostPosted: Mon Apr 18, 2016 1:50 am     Reply with quote
Yes.
This is a very important (and often misunderstood) question.
It's like the thing of people asking for an 'average'. Any one with some mathematical background will want to know that there are a very large number of different types of 'average'.
Then the one of using an old steel tape measure versus a 'modern' ultrasonic measure. Many people will say 'of course' the latter is 'more accurate'. "Look it says the distance is 4.384m". However read the fine print and you see that it says it's reading is +/-5mm, while the steel tape is actually a class 1 tape, and at the correct tension, for distances up to 10m, is quoted at +/-1.1mm....
Then (of course) the question of the relative 'accuracy' of integers versus floating point.
In this case, the poster is probably talking about long term 'drift' in the timing. This is going to depend on a huge range of factors, including the supply stability, the temperature range involved etc..
In the original code, setting a timer 'to' a value, is always going to result in lost ticks. The version from Ckielstra is a much better solution, and will be as accurate as the clock source for the PIC. If you need better than this, then things get relatively complex!....
