How to run a controller on very low speed
stoyanoff
PostPosted: Mon Feb 29, 2016 5:46 am     Reply with quote
Greetings! I want to use dsPIC30F5015 on very low speed. I think 32kHz should be OK! I tried to put 32kHz quartz as main oscillator, but it doesn't work. Can you help me?!
Thanks!
PostPosted: Mon Feb 29, 2016 6:11 am     Reply with quote
Ok I have to ask WHY? You do realize it'll take forever to run EVERY line of code? At least 1000s of time slower ?
Now to run at 32KHz, use an external oscillator and divide it down or use a watch xtal and 4049 to roll your own.Since I don't use dsPIC I can't say IF it can run from the internal 32KHx osc (if it has one ?).
EDIT: OK downloaded the datasheet, simplest way is a 4049 and 32KHz xtal though it will be snail slow and a real waste of PIC processor/speed.
Now I really want to know why as all operation will consume a LOW more power to execute.
stoyanoff
PostPosted: Mon Feb 29, 2016 7:08 am     Reply with quote
Hi! Can I use RC group instead of oscillator?!
Thanks!
PP: I need the low speed because of the motor control unit. The debugger doesn't give any real feedback on it's registers. So I need to improvise!
PostPosted: Mon Feb 29, 2016 7:30 am     Reply with quote
I read the datasheet page 152 that the LP mode ( 32KHz on sosc) can be shared with system clock, maybe that will work for you. Couldn't find the chart of RC mode which most PICs can run though....
It sure will be slow running !!
EDIT:
as for slow running, I did use a 4060 with 2.4576MHz xtal and /1024 to create a 2400 Hz clock THEN divide by 100 to get 24 Hz. This is the UART clock for my remote engery control system, could get 15 miles with it.
PostPosted: Mon Feb 29, 2016 10:02 am     Reply with quote
The lowest frequency mode, would be to use an external oscillator.
As Temtronic says a simple 4049, or a little crystal module.
EC mode supports operation down to DC.
Generally though the 'per instruction' power consumption rises at very low frequencies, and there is nothing that can be done at low speeds that couldn't be done by just writing the code to be slower. Your comment 'I need the low speed because of the motor control unit', doesn't really make any sense. I can do jobs hundreds of seconds per effective cycle, clocking at 60Mhz. Far the simplest way is to use the internal RC oscillator, and just write your code to give the speed required.
stoyanoff
PostPosted: Mon Feb 29, 2016 10:26 am     Reply with quote
I'll put RC oscillator. Now I'm looking into 70054 Microchip oscillator AN. On page 29 there is a graphic which says 300pF and 10k should be equal to around 75kHz!
I'll try it!
PostPosted: Mon Feb 29, 2016 10:58 am     Reply with quote
Just remember that RC oscillators are NOT 'precise' by any means and will vary widly with temperature and humidity. Maybe not a concern on the bench but in the field it's a big deal,that's why I went the 4060/xtal route.
I imaging 'startup 'time to big quite awhile as well. Obviously nothing is time critical in your test !!???
stoyanoff
PostPosted: Tue Mar 01, 2016 2:20 am     Reply with quote
There is a problem! I found the controller has internal RC 512kHz oscillator. I conducted blink test and everything works fine. The problem comes with the motor control unit. It seems this unit stays on the internal 8MHz oscillator in spite of I`ve sellected RC 512kHz oscillator.
I`ve tried with external RC oscillator - same result!
Any suggestions?!
PostPosted: Tue Mar 01, 2016 4:32 am     Reply with quote
What are you setting the prescaler to?.
This is what I was saying about using a higher speed. You have the PTPER register controlling the actual count, and a prescaler.
The prescaler is the third value in the setup_motor_pwm function
setup_motor_pwm(1,MPWM_FREE_RUN,64,0,0x7FFF);
Gives /64 prescaler.
You can then run the CPU at a much more sensible rate....
Prescaler can be 1, 4, 16 or 64.
Also, look at the 70268A data sheet already mentioned. This shows where Fpwm actually comes 'from' in th various clock routes.
