USB_CDC enum after Watchdog reset
Slim PICins
PostPosted: Thu Feb 25, 2016 11:37 am     Reply with quote
Usb_cdc working well, however, after watchdog (that I forced by message received) won't enumerate. The cable remains connected. It appears the PC must detach first then the sequence works OK. Hard power reset works OK.
Hmmmmmmmm, any ideas?
void ResetHandler(void)
       usb_detach();   // no help
PostPosted: Thu Feb 25, 2016 12:35 pm     Reply with quote
You should not be triggering the watchdog.
If a serial port is open, Windows will hold it open, and can't re-enumerate the device.
You need to add a monitor to your Windows application, that if it doesn't see communications in a while closes the port. Have the Windows application set DTR when it opens the port. Then write the PIC code to test for DTR, and only communicate if this is seen.
You've actually got to disconnect at the Windows end. The PIC can't do anything about this.
