how to access structures
pic_man
PostPosted: Wed Feb 24, 2016 3:19 am     Reply with quote
hi everyone
I am using ccs compiler version 4.124
I was seeing the example file rtctimer.c
In this example file structures are used.and to access elements of those structures "->" symbol is used like
unixTime += timeT->tm_sec;
we can also use it as this way
unixTime += timeT.tm_sec;
what is the difference between both?
From where i can read and study about supported syntax in ccs?
PostPosted: Wed Feb 24, 2016 3:51 am     Reply with quote
Read a C textbook!...
-> is used as a shorthand when dealing with a pointer to a structure.
If 'p' is a pointer to a structure, then p->member accesses the member in the structure being pointed to.
The -> is used inside a function, where timeT has been passed as a pointer.
It's a shorthand for (*timeT).member
