Where is strcpy function located?
davidd
PostPosted: Wed Feb 10, 2016 3:19 pm     Reply with quote
Do not see it in STRING.H, Only see strncpy.
SOLVED:
1. STRING.H is NOT required for for strcpy.
2. Be sure to use STRCPY and NOT STRCOPY
You will get function used but not defined error.
Thanks!
PostPosted: Wed Feb 10, 2016 4:05 pm     Reply with quote
There is no source code for it. It's an intrinsic function. I think, after
looking at the .LST file, it's because the compiler authors can hand-code
strcpy much more efficiently in ASM than the compiler can compile it.
PostPosted: Thu Feb 11, 2016 2:20 am     Reply with quote
It's also because it is internally overloaded to support ROM and RAM strings.
