Slim PICins
| USB_CDC enum |
Posted: Thu Feb 04, 2016 10:29 am |
Compiler 4.128
PIC18F87J50
This code allows fairly reliable enumerations (USB To UART COM10) upon cable connection, as long as I have the "delay_ms(250)" line in. If I lower the delay or remove this line, I get "Device not Recognized" or "Device won't Start".
Any ideas? Thanks
| Code: | void main()
InitSystem();
//setup_adc_ports(NO_ANALOGS);
setup_timer_3(T3_DISABLED | T3_DIV_BY_1);
setup_timer_4(T4_DISABLED,0,1);
// Use usb_init_cs()'connection sense' instead of usb_init()
usb_init_cs(); //Original
//usb_cdc_init();//Original
do
if(usb_attached())
usb_task();
delay_ms(250);
if(usb_enumerated())
OUTPUT_HIGH(LED_PIN);
if((usb_cdc_carrier.dte_present) && (bEnumeratedFlag == FALSE))
printf(usb_cdc_putc,"Hello, Universal Controller USB!\n\r");
printf(usb_cdc_putc,"Enter ASCII command or '?'\n\r");
bEnumeratedFlag = TRUE;
UsbReceiveTask();
OUTPUT_LOW(LED_PIN);
usb_init_cs();
{ // The cable has been disconnected
bEnumeratedFlag = FALSE;
usb_cdc_init(); //clear buffers if disconnected
}while(TRUE);
Posted: Thu Feb 04, 2016 3:30 pm |
The problem is that you keep calling init_cs.
This only needs to be called once.
What is happening, is it sees the cable as attached, but it is not enumerated (yet). Your code then calls init_cs again, which resets the hardware, and prevents enumeration. So it keeps looping round not enumerating.
By adding the delay you give it time to enumerate.... |
