Can't access bit field bits
Goto page 1, 2  Next
CMatic
PostPosted: Tue Jan 19, 2016 11:06 am     Reply with quote
CCS PCM C Compiler, Version 5.026
I have defined a structure as follows:
typedef struct {
   int1 Units:1;        //bit0 - Units LSB
   int1 Sound:1;        //bit 1- sound
   int1 Alarm:1;        //bit 2- Alarm
   int1 Bcklgt:1;       //bit 3- Bcklgt
   int1 Autopwroff:1;   //bit 4- Autopwroff
   int1 BatLow:1;       //bit 5- BatLow
   int1 Reserved:1;     //bit 6- Reserved
   int1 Factory:1;      //bit 7- Factory MSB
} user_t;
user_t config = 0x80;
And when I try to use the variable config.Factory in another module it gives me error with Factory underlined as the error. I am using extern config in the other module. When I hover my cursor on config it shows all elements but Factory shows "Expecting union/structure". Please help and thanks in advance.
RF_Developer
Re: Can't access bit field bits
PostPosted: Tue Jan 19, 2016 11:25 am     Reply with quote
You have not defined a structure with a byte bit field. you have defined a structure with eight int1s (i.e. booleans) each of one bit wide, which they are anyway!
Even with a byte-wide bit field you would not be able to access all the bits, i.e. the byte this way. To do that requires a union:
typedef union user_t {
   int8 All_Bits;
   struct {
   int8 Units:1;        //bit0 - Units LSB
   int8 Sound:1;        //bit 1- sound
   int8 Alarm:1;        //bit 2- Alarm
   int8 Bcklgt:1;       //bit 3- Bcklgt
   int8 Autopwroff:1;   //bit 4- Autopwroff
   int8 BatLow:1;       //bit 5- BatLow
   int8 Reserved:1;     //bit 6- Reserved
   int8 Factory:1;      //bit 7- Factory MSB
   } Single_Bits;
} My_union;
My_union.All_Bits = 0x80;
My_union.Single_Bits.BatLow = FALSE;
if (My_union.Single_Bits.Factory)
  // Do stuff
You need to check up on how to define bit fields and unions. Also, you do need to be careful of the bit order. CCS C provides a more certain, but non-portable way of accessing bits. Personally, I wouldn't use bit fields at all, just booleans.
PS: I hope I got that right, my bit field knowledge is not all it should be, and my unions can be a bit sketchy.
CMatic
PostPosted: Tue Jan 19, 2016 11:41 am     Reply with quote
RF_Developer Thanks very much for replying. Yes, I can see why you also don't want to use bit fields. Since I am trying to conserve EEPROM space, can you suggest what would be a better way to save users configurations?
gaugeguy
PostPosted: Tue Jan 19, 2016 12:22 pm     Reply with quote
#bit will do what you want
int8 config
#bit Units = config.0
#bit Factory = config.7
CMatic
PostPosted: Tue Jan 19, 2016 1:22 pm     Reply with quote
int8 config
Thanks for the comment, I am trying this out now and will post my results.
CMatic
PostPosted: Tue Jan 19, 2016 6:14 pm     Reply with quote
Guageguy I tried your #bit suggestion but it did not work.
I tried the config.Factory = 1; And the compiler did compile it correctly, however, when I tried to use this statement in another module, this statement does not work? Am I missing something here?
drolleman
PostPosted: Tue Jan 19, 2016 9:51 pm     Reply with quote
you didn't do it properly. #bit works I use it in almost every project.
CMatic
PostPosted: Tue Jan 19, 2016 10:16 pm     Reply with quote
I tried the following and the compiler shows error on config.0 when I hover over it, it says "expecting a declaration" ?
here is the code snip.
int8 config = 0x80;
#bit Units = config.0;
#bit Sound = config.1;
#bit Alarm = config.2;
#bit Bcklgt = config.3;
#bit Autopwroff = config.4;
#bit BatLow = config.5;
#bit Reserved = config.6;
#bit Factory = config.7;
drolleman
PostPosted: Tue Jan 19, 2016 11:43 pm     Reply with quote
put complete code up.
what you have here factory will be 1 all other bits will be 0
if config = 0x34 = 00110100b
then
#bit Units = 0
#bit Sound = 0;
#bit Alarm = 1;
#bit Bcklgt =1;
#bit Autopwroff = 0;
#bit BatLow = 1;
#bit Reserved = 0;
#bit Factory = 0;
CMatic
PostPosted: Wed Jan 20, 2016 12:23 am     Reply with quote
Don't mean any disrespect but the code is very large and in 7 modules.
The structure is as follows:
struct {
 } config;
#locate config = 0x2000 //define where this variable will be located
Using the above structure, I am able to set Factory bit = 1, as follows:
config.Factory =1;
However, in my other module (where I declare:extern config), when I try to use config.Factory = 1; I get error saying "Expecting structure/union", and this is where I don't understand the compiler? Thanks for looking into it.
This is working in my main function.
gaugeguy
PostPosted: Wed Jan 20, 2016 7:24 am     Reply with quote
You should not use both the structure and #bit.
Delete the structure and access the bits as
Factory = TRUE; or Factory = 1;
config = 0x80;
PostPosted: Wed Jan 20, 2016 7:51 am     Reply with quote
You still have not told the people working on your problem what PIC you
are using, and if you are using Multiple Compilation Units or not.
drolleman
PostPosted: Wed Jan 20, 2016 2:22 pm     Reply with quote
your structure uses 8 bytes of data. if you use
int8 config;
this uses 1 byte of data or 8 bits isn't that what you want?
PostPosted: Wed Jan 20, 2016 2:32 pm     Reply with quote
int8 config;
No. He is using bitfields. The :1 means use one bit of the int8, as if this is an integer. You can use sizes like :4 to give you nibble sized integers.
Used correctly, this is perfectly acceptable, but his declarations are problematic. The bitfield, it needs to be declared in all modules using it.
CMatic
PostPosted: Wed Jan 20, 2016 3:20 pm     Reply with quote
PCM programmer The pic is 16f1825 and there is no multiple compilations
Goto page 1, 2  Next
Page 1 of 2
