PIC18F4550 and brownout fuses
neo19
PostPosted: Mon Jan 18, 2016 2:40 am     Reply with quote
I'm working with a PIC18F4550.
My version of CCS C COMPILER is 5.030
My version of CCSLOAD is V5.006
My problem is I would like to use brownout options:
- Reset when brownout is detected
- and brownout reset at 4.3V
So it seems very simple.
My configuration is :
#include <18F4550.h>
#device adc=10
#device ICD = TRUE
#fuses HSPLL, NOWDT, NOPROTECT, NOLVP, NODEBUG, USBDIV, PLL5, CPUDIV1, VREGEN
#use delay (clock=48M)
I insert
#fuses BROWNOUT,BORV43
and when I check the file .hex with CCSLOAD I see that the configuration is not good:
- no brownout detect NOK
- brownout reset at 4.3V OK
I've checked the fuses BROWNOUT,BORV43 in the file PIC18F4550.h and it's OK.
I could force the brownout detection with CCSLOAD but it's not what I want to do.
Someone has and idea why #fuse brownout is not recognised?
Best regards,
Fabrice
PostPosted: Mon Jan 18, 2016 4:29 am     Reply with quote
5.006, was a beta version at best. I'm afraid it's just an internal typo in the database. It was fixed by 5.009. However I'd not trust anything before perhaps 5.012, to be a usable version.
neo19
PostPosted: Mon Jan 18, 2016 9:19 am     Reply with quote
RF_Developer
PostPosted: Mon Jan 18, 2016 9:23 am     Reply with quote
With #device ICD = TRUE some fuses are forced to turn some things off. These include watchdog, low voltage detector and most importantly for you, brownout.
Comment out that line - only use it when you are intending to use an ICSP debugger.
neo19
PostPosted: Mon Jan 18, 2016 9:28 am     Reply with quote
So, I've downloaded the latest version of ccsload and it the same result.
If I comment out the line #device ICD = TRUE, it's OK now.
Thanks a lot,
Fabrice
PostPosted: Mon Jan 18, 2016 9:35 am     Reply with quote
You'd also find the watchdog turned off, and several other things.
The brownout won't work with ICD, so they turn it off.
neo19
PostPosted: Mon Jan 18, 2016 10:01 am     Reply with quote
So I will do very careful and check all of the different fuses.
Thanks a lot
Fabrice
