RTC problem
noman yousaf
RTC problem
PostPosted: Fri Jan 08, 2016 8:01 pm     Reply with quote
hi,
I opened 2416.c
and changed the device address from 0A to 0D (for DS1307 RTC).
and removed oring for use the 3 msb address bits.
then i saved it as 1307.c
will it work as RTC instead of EEPROM?
please guide
PostPosted: Fri Jan 08, 2016 8:37 pm     Reply with quote
No. Not at all.
Use the real ds1307 driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=23255
noman yousaf
PostPosted: Sat Jan 09, 2016 7:06 am     Reply with quote
PCM programmer wrote:
No. Not at all.
in that code, there is an error in DS1307.c (the code written in upper)
error is about pinc3,c4.
and there is no any definition of controller etc in such code.
PostPosted: Sat Jan 09, 2016 9:03 am     Reply with quote
these lines in the driver...
#define RTC_SDA PIN_C4
#define RTC_SCL PIN_C3
define(tell the driver) which pins YOU attach the DS1307 to.
From your description you're probably using a PIC that does NOT have C3 or C4 I/O pins.
simple copy the driver to my_1307.c
edit these lines
replacing PIN_C4 with the pin YOU want to be the 'data' pin
and repalce PIN_C3 with the pin YOU want to be the 'clock' pin
You should not edit the original ds1307.c driver code otherwise you can easily 'damage' it.
jay
noman yousaf
PostPosted: Thu Jan 14, 2016 5:47 pm     Reply with quote
edit these lines
jay
I am using pic18f458 which has pins C4 and C3.
noman yousaf
PostPosted: Thu Jan 14, 2016 5:53 pm     Reply with quote
edit these lines
jay
can i not use #use12c. . , for making my own code to drive any i2c device? for example, in 24cxx i2c is used. i just want to make new code using i2c for rtc by changing device code (odh)
PostPosted: Thu Jan 14, 2016 7:08 pm     Reply with quote
There sure is. See this section in the driver link:
Example use:
#include <18F452.h>
#device adc=8
#fuses NOWDT,WDT128,HS, NOPROTECT, NOOSCSEN, BROWNOUT, BORV20, NOPUT, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOWRTB, NOWRTC, NOCPD, NOCPB, NOEBTR, NOEBTRB
#use delay(clock=20000000,RESTART_WDT)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PC,errors)
#include <ds1307.c>
The controller in the example is the 18F452, but you can change it.
Note that the driver is saved as ds1307.c and then an #include line is used
to include it in the example file. This is the normal way of doing a program.
ds1307 driver and example file:
i just want to make new code using i2c for rtc by changing device code (0dh)
It won't work. An eeprom chip is entirely different than an RTC chip.
You must use a driver file written for the ds1307.
