Code library for TFT LCD 128x160
stoyanoff
PostPosted: Sun Jan 03, 2016 10:36 am     Reply with quote
Is there a CCS library for TFT LCD display (SPI or I2C interface) 128x160 dots?!
Thanks!
PostPosted: Sun Jan 03, 2016 1:50 pm     Reply with quote
don't know if this is what you want....
but found this...
https://www.ccsinfo.com/forum/viewtopic.php?p=151296
.. might be a 'starting point' ??
I'm making a huge assumptuion that most tft lcd displays have a 'similar' command set and pinout....
stoyanoff
PostPosted: Mon Jan 04, 2016 4:56 am     Reply with quote
I have this Click
PostPosted: Mon Jan 04, 2016 6:41 am     Reply with quote
hmm since the ad says 'ardunio' in it as well as ST7735, I found a driver/code on mikroc...... website. It should be that hard to convert into CCS C.
Maybe google 'ST7735 CCS C code driver' or check the 'code library' here ?
You can't be the first one using the device !!
There has to be good datasheet/info about the device or the ST7735.
Just be sure to do 'low level' testing after hardware is properly done.
Also don't assume that 'compatible' means 100% the same!!
