16F18344 (Solved)
in_nursery
16F18344 (Solved)
PostPosted: Tue Dec 15, 2015 8:43 am     Reply with quote
Hi all
I try to make this work but the clock seems not running.
#include <16F18344.h>
#fuses NOEXTOSC
#fuses ECH
#fuses RSTOSC_HFINTRC
#use delay(internal=8MHz)
#define PIN_GREEN    PIN_C3   // Green LED
//Setup Clock
setup_oscillator(OSC_HFINTRC_8MHZ);
       output_high(PIN_GREEN);
       output_low(PIN_GREEN);
The green LED start and that's all, the prog is not running, what did I miss ?
PostPosted: Tue Dec 15, 2015 9:56 am     Reply with quote
you should add another delay_ms(1000);
after the output_low(PIN_GREEN);
as coded it turns on LED for 1 second then turns it off then on again.....
a 'scope would see it 'flash', but not us humans !
in_nursery
PostPosted: Tue Dec 15, 2015 10:05 am     Reply with quote
Oh NOOOOO I'm so bad Evil or Very Mad , I focus on everything else and I haven't seen that.
Thanks Temtronic
PostPosted: Tue Dec 15, 2015 12:57 pm     Reply with quote
Hate to say WHY I know about this .......
Welcome to the club!!
gpsmikey
PostPosted: Wed Dec 16, 2015 10:47 pm     Reply with quote
Yep - been there, done that Shocked
mikey
mikey
old engineering saying: 1+1 = 3 for sufficiently large values of 1 or small values of 3
