Function pointer in a structure makes a compiler mess-SOLVED
rikotech8
PostPosted: Sun Dec 13, 2015 11:58 am     Reply with quote
Compiler 5.025
This is unacceptable:
struct process
   unsigned char* name;
   int (*func)(void);
   int8 called;
   struct process* p_process;
}process_riko;
When I remove int (*func)(void); everything works.
A person who never made a mistake never tried anything new.
PostPosted: Sun Dec 13, 2015 12:23 pm     Reply with quote
try typedef'ing the function pointer type first:
typedef int (*func_type)(void);
struct process
   func_type func;
   int8 called;
}process_riko;
Also keep in mind, I think there was a version 5 change somewhere that corrected how function pointers worked. I don't remember how far back that was though.
PostPosted: Sun Dec 13, 2015 12:53 pm     Reply with quote
In addition to the typedefing, your version of the compiler also has the
bug listed in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=54461
Which can be fixed like this:
struct process
   func_type func;
   int16 dummy;     // *** Added to fix bug in link
   int8 called;
}process_riko;
This bug was fixed in compiler vs. 5.051.
rikotech8
PostPosted: Tue Dec 15, 2015 1:10 am     Reply with quote
Thank you guys. It works with typedef. I hope CCS will fix that problem in the future versions.
PostPosted: Tue Dec 15, 2015 7:47 am     Reply with quote
Make sure to email them a bug report so they will hopefully be able to fix that.
