Problem with printf using terminal
grogue
PostPosted: Tue Dec 08, 2015 12:23 pm     Reply with quote
Hey guys, I'm new here and I'm having some problems with the serial com.
I'm using a RS232 to USB converter and Tera Term to emulate a terminal in my computer. The thing is \f isn't working in this terminal and the information keeps coming over and over without erasing the old information. When I test the code in the virtual terminal on ISIS, it works.
I'm really going crazy here.
The program:
#include <Serial.h>
int x=0;
int y=0;
float value=0;
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   //TODO: User Code
while(true){
   value=3.4+(3.4*x);
   if(input(pin_a0) && y==0){
      x++;
      delay_ms(20);
      printf("\fNumber          Value");
      delay_ms(20);
      printf("\n      %u                        ",x);
      printf("$%f",value);
      y=1;
   if(!input(pin_a0)){
      y=0;
Ps: Sorry 'bout my bad english
PostPosted: Tue Dec 08, 2015 1:59 pm     Reply with quote
The command sequence for a VT terminal to clear the screen, is <ESC>[2J, not the 'form feed'. So "\x1B[2J" in printf.
You can set Tera term to automatically clear the screen on a page scroll, with the setting "ScrollWindowClearScreen=on", in the configuration file/
grogue
PostPosted: Tue Dec 08, 2015 3:06 pm     Reply with quote
Thanks for the answer, Ttelmah!
I did everything you said but still not working.
The ScrollWindowClearScreen was on. I changed it to off just to test it but it changed nothing.
With the changes, the program is this:
#include <Serial.h>
int x=0;
int y=0;
float value=0;
   setup_vref(FALSE);
   //TODO: User Code
while(true){
   value=3.4+(3.4*x);
      x++;
      delay_ms(20);
      printf("\x1B[2J Number       Value");
      delay_ms(20);
      printf("\n      %u                        ",x);
      y=1;
   if(!input(pin_a0)){
      y=0;
Is this alright?
PostPosted: Tue Dec 08, 2015 3:32 pm     Reply with quote
Change this:
to this:
printf("%x[2J Number       Value", 0x1b);
I know that there is probably a shortcut to getting printf to insert the escape via some sort of escape sequence (i.e. "\something"), but I have no idea what that is.
grogue
PostPosted: Tue Dec 08, 2015 4:01 pm     Reply with quote
Hey newguy, thanks for the answer!
Still not working. I'm receiving informations such as: "30.601[b2J Number Value" , "$27.201b[2J Number Value", etc.
The terminal is not erasing the old information and I don't know why, but the float number is coming before "Number".
grogue
PostPosted: Tue Dec 08, 2015 4:03 pm     Reply with quote
In fact, the first time I use it the information is "1b[2J Number". The float number just appear after this first information.
PostPosted: Tue Dec 08, 2015 6:03 pm     Reply with quote
I'm at a loss. I thought that the compiler might not recognize the "\x" escape sequence, so that's why I suggested what I did.
Where your // TODO: User code line is, try inserting
printf("\n\n\n\n\n");
I don't know if that will help but my line of thought is that the PC or the serial-USB dongle is having issues synchronizing the data stream from your PIC.
You could also alter your program to simply printf() a dummy sentence - simply to help you diagnose the proper screen wipe/refresh character sequence, then put your desired code back in.
Try printing
Hello 1
(delay 1 second)
(screen erases)
Hello 2
(delay 1 second)
(screen erases)
etc.
PostPosted: Tue Dec 08, 2015 10:59 pm     Reply with quote
TeraTerm has a 10000 line buffer. If I go into the Setup / Window menu
in TeraTerm, and untick the tickbox for "Scroll Buffer", then the
following program works.
It displays blocks of lines of x, y, and z. It clears the screen and
homes the cursor after displaying each block:
#include <18F4620.h>
#fuses INTRC_IO, NOWDT
#use delay(clock=4M)
int8 i;
for(i=0; i<10; i++)
    printf("Line %u xxxxxxxxxxxxxxxxxxxxxxxxx \n\r", i);
delay_ms(2000);
printf("\x1b[2J"); // Clear screen
printf("\x1b[H");  // set cursor to 0,0
for(i=0; i<10; i++)
    printf("Line %u yyyyyyyyyyyyyyyyyyyyyyyyy \n\r", i);
delay_ms(2000);
for(i=0; i<10; i++)
    printf("Line %u zzzzzzzzzzzzzzzzzzzzzzzzz \n\r", i);
delay_ms(2000);
while(TRUE);
grogue
PostPosted: Thu Dec 10, 2015 10:46 pm     Reply with quote
PCM programmer, thank you very much!
The problem was really the scroll buffer option! Now it works like a charm! Wink
Thanks everybody! You guys helped me a lot! Very Happy
