Parsing string to function.. what am i doing wrong?
Jody
PostPosted: Wed Dec 02, 2015 4:27 pm     Reply with quote
Want to parse a string to a function..
The function is in another file and it looks like that that is the problem...
I have include all mine files... anyone a idea??
Main.c:
#include <main.h>
#include <commands.c>
#include <stdlib.h>
#include <string.h>
#include <stddef.h>
char slave_1[3] = "323";
char slave_2[5] = "green";
char slave_3[3] = "on";
      setup_adc_ports(sAN15);
      setup_timer_4(T4_DISABLED,0,1);
      setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
       commands(&slave_1, &slave_2, &slave_3);
Commands.c:
#include <string.h>
#include <stdlib.h>
char    string_rs485[MAXINPUTBUF];
/* The following typedef's should be adjusted for the particular platform.
 * CRC-8     x^8  + x^2 + x + 1
 * prototypes */
int generate_8bit_crc(char* data, int16 length, int pattern)
   int   *current_data;
   int   crc_byte;
   int16 byte_counter;
   int   bit_counter;
   current_data = data;
   crc_byte = *current_data++;
   for(byte_counter=0; byte_counter < (length-1); byte_counter++)
      for(bit_counter=0; bit_counter < 8; bit_counter++)
         if(!bit_test(crc_byte,7))
            crc_byte <<= 1;
            bit_test(*current_data, 7 - bit_counter) ?
               bit_set(crc_byte,0) : bit_clear(crc_byte,0);
            continue;
         crc_byte <<= 1;
         crc_byte ^= pattern;
      current_data++;
         crc_byte <<= 1;
         continue;
      crc_byte <<= 1;
   return crc_byte;
    |Addr |   commando   | status | CRC |
   | 001 |   groen      |  off   | 034 |
void commands(char *slave_address, char *slave_commando, char *slave_status)
   char space[1], slash_n[2], crc_string[3];
   int16 crc_calculated, lengte;
   strcpy(space, " ");
   strcpy(slash_n, "\n ");
   strcat(string_rs485, *slave_address);
   strcat(string_rs485, space);
   strcat(string_rs485, slave_commando);
   strcat(string_rs485, slave_status);
   crc_calculated = generate_8bit_crc(string_rs485, lengte, 0x107);
   ITOA(crc_calculated, 10, crc_string );
   strcat(string_rs485, crc_calculated);
   strcat(string_rs485, slash_n);
Main.h:
#include <18F87J50.h>
#device adc=16
#device PASS_STRINGS=IN_RAM
#define   MAXINPUTBUF   20
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(clock=20000000)
Regards,
Jody
PostPosted: Wed Dec 02, 2015 5:54 pm     Reply with quote
I haven't looked through the rest of your code, but right off the bat there is some C programming 101 stuff:
The string "323" is 4 characters long and "green" is 6 characters long.
Possible solutions:
char slave_1[4] = "323";
char slave_2[6] = "green";
or
char slave_1[] = "323";
char slave_2[] = "green";
char slave_3[] = "on";
PostPosted: Wed Dec 02, 2015 5:58 pm     Reply with quote
In addition to that,
The first line below has a bug. A pointer is passed by name, not
by *name. Remove the * on the first line:
Also, this line is wrong. Pointers to arrays are passed by name, and
not with &name. Remove all the & from the line below:
Jody
PostPosted: Thu Dec 03, 2015 4:09 am     Reply with quote
Yes!!
That did it...
Now reading it it all make sense.
I was fiddling half a day with it!
Thanks for pointing me in the right direction!!!
Regards,
Jody
