Weird Division [SOLVED]
scanan
PostPosted: Wed Dec 02, 2015 8:08 am     Reply with quote
hi,
what could be the problem ?
ccs compiler ver 4.135
PIC18F45K80
signed int32 ldvalue;
float scalefactor;
signed int32 setload=100;
ldvalue=214001;
            printf("ldvalue=%Ld",ldvalue);
            scalefactor=(float)ldvalue/setload;
            printf("scalefactor= %.6f \r\n",scalefactor);
the result shown on the terminal is a negative number
interesting
is it a printf error?
Dr Suleyman CANAN
R&D Electronic Engineer
https://suleymancanan.wordpress.com
Do whatever you do with amateur spirit -
But always feel professional.
PostPosted: Wed Dec 02, 2015 8:30 am     Reply with quote
First, _what compiler version_.
This is one of the key things that must be said for any problem like this.
However, printf on a lot of CCS versions, gives 'unusual' results, if it is used without a width limit. Try with %8.6f.
scanan
PostPosted: Wed Dec 02, 2015 10:42 am     Reply with quote
compiler version ccs 4.135
PIC18F45K80
Dr Suleyman CANAN
PostPosted: Thu Dec 03, 2015 3:23 am     Reply with quote
That is certainly round the area where the problem existed if you did not limit the width. Have you tried with the width limit? (understand the value will still print exactly the same, since if the digits in front of the decimal make it overflow the specified width, the format will automatically expand to give the space required). Also since a 'float' only has just over 6 digits of real precision, printing 6 decimals is rather pointless....
Have two versions later (works), and one a couple older. On the older one, it goes wrong in all sorts of ways. Changed the format to %9.8f, and it started working. So you are almost certainly right in the area where there were problems if you specified &f without a width.
scanan
PostPosted: Fri Dec 04, 2015 2:10 pm     Reply with quote
Thanks for your suggestions.
After some trial I figure out that x.4 is ok.
But 5 6 decimal results as error.
Dr Suleyman CANAN
