[SOLVED] internal oscillator with PIC18F45K80
Goto page Previous  1, 2, 3, 4
vas57
PostPosted: Sat Apr 11, 2026 12:54 pm     Reply with quote
Cine ma poate ajuta cu un sfat ?
Incerc sa scriu cu un modul PN532(NXP), intr-un mifare desfire ev1 o aplicatie cu programul de mai jos, dar nu orimesc confirmarea pentru realizarea ei. Este formatul comenzilor gresit? Programul imi trezeste cardul si imi scoate UID-ul lui.
[#include <18F46K22.h>
#fuses NOWDT, NOPROTECT, NOLVP, NOMCLR
#use delay(crystal=20000000)
// UART1 la 115200
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7, stream=NFC_BUS, errors)
unsigned int8 i, len;
unsigned int8 buffer[64];
// 1. Trezire (Wake-up)
unsigned int8 const WAKE[] = {0x55,0x55,0x00,0x00,0x00,0x00,0x00,0xFF,0x03,0xFD,0xD4,0x14,0x01,0x17,0x00};
// 2. AUTO-POLL (Inlocuieste SCAN si RATS) - DCS: B9
unsigned int8 const POLL[] = {0x00,0x00,0xFF,0x05,0xFB,0xD4,0x60,0x01,0x01,0x10,0xB9,0x00};
// 3. CREATE APP (40 01 CA) - DCS: 20
unsigned int8 const CREATE[] = {0x00,0x00,0xFF,0x09,0xF7,0xD4,0x40,0x01,0xCA,0x12,0x34,0x56,0x0F,0x01,0x20,0x00};
setup_adc_ports(NO_ANALOGS);
// TREZIRE INITIALA
for(i=0; i<15; i++) fputc(WAKE[i], NFC_BUS);
while(TRUE) {
// Gole?te orice rest din Rx
while(kbhit(NFC_BUS)) fgetc(NFC_BUS);
// 1. SCANARE (Cea care a mers mereu) - DCS: E1
unsigned int8 const CMD_S[] = {0x00,0x00,0xFF,0x04,0xFC,0xD4,0x4A,0x01,0x00,0xE1,0x00};
for(i=0; i<11; i++) fputc(CMD_S[i], NFC_BUS);
delay_ms(200);
// 2. ACTIVARE DATE (RATS) - DCS: D5
// Trimitem fortat, imediat dupa scanare
unsigned int8 const CMD_R[] = {0x00,0x00,0xFF,0x03,0xFD,0xD4,0x56,0x01,0xD5,0x00};
for(i=0; i<10; i++) fputc(CMD_R[i], NFC_BUS);
delay_ms(200);
// 3. CREARE APLICATIE - DCS: 20
unsigned int8 const CMD_C[] = {0x00,0x00,0xFF,0x09,0xF7,0xD4,0x40,0x01,0xCA,0x12,0x34,0x56,0x0F,0x01,0x20,0x00};
for(i=0; i<16; i++) fputc(CMD_C[i], NFC_BUS);
delay_ms(1500);
][/code]
PostPosted: Sun Apr 12, 2026 6:55 am     Reply with quote
seems to be Romanian....Google helped !
Who can help me with an advice?
I'm trying to write with a PN532(NXP) module, in a mifare desfire ev1 an application with the program below, but I can't get the confirmation for its execution. Is the command format wrong? The program wakes up my card and gives me its UID.
dyeatman
PostPosted: Sun Apr 12, 2026 7:28 am     Reply with quote
Several problems I have with this post:
1. Piggybacked on another thread from more than EIGHT years ago when they
should have started a new one
2. Posted in Romanian rather than English so most users here don't
know what he said starting out without a translator.
3. Looks like the program structure needs a fair amount of work. Lots
of delays and not using interrupts, etc.
PostPosted: Sun Apr 12, 2026 9:25 am     Reply with quote
Also, the code itself is commented in English, which suggests he has
taken it from somewhere. We have no way of knowing that his hardware
is correct for this code. Has he got a 20MHz crystal?. Is the unit correctly
wired to the serial pins?. Is the chip even running?.
These all need to be tested and proven before trying to run this code.
PostPosted: Sun Apr 12, 2026 12:02 pm     Reply with quote
and then there's the 5 volt PIC with 3 volt peripheral problem......
...I don't assume any 3 volt 'device' is truly 5 volt compatible.
dyeatman
PostPosted: Sun Apr 12, 2026 2:09 pm     Reply with quote
And then there's the 5 volt PIC with 3 volt peripheral problem......
yeah...that too! Shocked
PostPosted: Mon Apr 13, 2026 10:54 am     Reply with quote
Good point. It would actually be that the 5v device (the PIC), will require
signals that go to about 4v on it's serial input, so without level translation,
it is not going to work.
Hardware details of where he got the code from, really are essential....
Looking at the chips, this is the most likely problem.
The communication device supports 5v operation, but has an internal LDO,
and the communication connections are designed for 3v operation.
Page 4 of 4
