#use rs232 ..... STOP bit / PARITY bit (default settings)
haseeb
PostPosted: Thu Oct 01, 2015 5:49 am     Reply with quote
hi
When using the #use rs232, i have seen many CCS exampls that declare as follows...
#use rs232(baud=9600, xmit=PIN_A2,rcv=PIN_A3)
Many of the examples do not state the arguments STOP and PARITY bits. So if i do not state the two arguments, does that mean the CCS compiler will default set the PIC UART to the following values....
8 bits
No PARITY bit
1 STOP bit
PostPosted: Thu Oct 01, 2015 6:37 am     Reply with quote
It _should_ be in the manual under USE RS232..... but yes, the CCS default is the 'defacto' standard of 8 bits, no parity and 1 stop bit.
You should always add 'ERRORS' to the options when using a hardware UART.It'll prevent the code from 'locking up' when an 'overrun' condition happens. That's when more than 2-3 characters come into the UART and not serviced.
haseeb
PostPosted: Thu Oct 01, 2015 6:51 am     Reply with quote
thanks for the information and confirmation Smile
i did check before i uploaded the post.....it says in the CCS manual (under #use rs232) that the the STOP bit is default 1 bit.....however there is no mention of the default values for PARITY and DATA bits
PostPosted: Thu Oct 01, 2015 7:02 am     Reply with quote
The chip itself (if using the hardware UART), cannot generate parity, and generates just one stop bit. 'Parity' on the PIC (except for a few of the DSPic's) has to be generated in software, by switching to using 9 bits, and writing the parity bit into this 9th bit. So as originally implemented (before the software RS232 was added), these defaulted to what the chip could do.
Unfortunately the compiler has moved on, but some parts of the manual leave out things like this that were 'implicit' in the early versions....
Funnily though, I'm sure the manual _used_ to actually say that 8,N,1 was the default. It looks as though this has been 'lost' somewhere in the past!....
PostPosted: Sat Oct 03, 2015 5:51 am     Reply with quote
The only terminal that I used that needed 2 stop bits was the Teletypes like the ASR-33. Being 100% mechanical even at the lightning speed of 110 Baud, it took 'quite awhile' for it to get ready to print the next character.
Now my remote energy control systems use 22-n-2 . That's 22 bits, no Parity, 2 stop bits and run at 24 baud, yes 24 characters per second. Have to use software driver for the communications as no UART understands 22 bits OR 24 baud !
guy
PostPosted: Sun Oct 04, 2015 4:07 pm     Reply with quote
DMX512 also has 2 stop bits if I remember correctly.
