RLScott
| Very serious bug - code ignored in #INT_GLOBAL |
Posted: Mon Sep 28, 2015 9:13 am |
The following block of code in an #INT_GLOBAL routine fails to compile anything for the code that restores scratch0:
.................... if(PIR1.TMR1IF)
00FE: BTFSS F9E.0
0100: BRA 0112
.................... PIR1.TMR1IF = 0;
0102: BCF F9E.0
.................... scratch0 = Tmr1Overflow+1;
0104: MOVLW 01
0106: MOVLB 1
0108: ADDWF xCC,W
010A: MOVWF 00
.................... Tmr1Overflow = scratch0;
010C: MOVFF 00,1CC
0110: MOVLB 0
.................... scratch0 = savedScratch0;
.................... scratch1 = savedScratch1;
0112: MOVFF 43,01
.................... #asm
.................... RETFIE 1 ;..fast return restores registers
0116: RETFIE 1
.................... #endasm
The use of scratch0 was devised to illustrate a minimal code failure and not exactly what led me to investigate this. The PIC is a 18F24K22 and the compiler is the command-line PCH Version 4.128 running from MPLAB. The relevant definitions are:
| Code: | #byte scratch0=0
#byte scratch1=1 |
since these are the scratch locations used by the compiler in some complex calculations.
So far, by trying variations on this theme, here is what I have found:
1. The exact same block of code compiles correctly when placed in an ordinary function (not a #INT_GLOBAL).
2. The restore of scratch0 compiles fine if the previous code is not an "if" block.
3. The restore of scratch0 compiles fine if I make seemingly insignificant changes to the previous "if" block, like replacing the "if" condition by a test of a general RAM variable and not a bit test of a SFR. (I think it has to do with bank selection.)
4. If I switch scratch0 and scratch1, it is the scratch1 code that compiles to nothing. In other words, the first such assignment compiles to nothing.
5. If I redefine scracth0 to any address besides 0, 1, 2, 3, it compiles fine. The compiler is apparently making a special effort to recognize its own scratch locations. _________________ Robert Scott
Real-Time Specialties
Embedded Systems Consulting |
Posted: Mon Sep 28, 2015 1:09 pm |
4.128, is rather old.
There were quite a few problems with some compilers round this time.
I do remember something similar being discussed. Even the behaviour with the action depending on what was in front, is familiar. If I remember a syntax was found to avoid the problem but I can't remember what it was. |
RLScott
Posted: Mon Sep 28, 2015 1:33 pm |
| Ttelmah wrote: | 4.128, is rather old.
My workaround is to restore FSR0 first and then restore the scratch registers. Then, for some reason, all statements compile correctly. _________________ Robert Scott
