MTCH112
JCS83
MTCH112
PostPosted: Wed Sep 23, 2015 7:59 am     Reply with quote
Hi everyone,
Has anyone here ever worked at the MTCH112 (mTouch chip). I'm having some problems with the read memory command. Someone for discuss about?
Thanks.
PostPosted: Wed Sep 23, 2015 11:32 am     Reply with quote
What's your problem?.
It is fairly standard I2C, except for the checksum:
#define CHIP_ADDRESS 0xE6
#define READ 1
int1 read_registers(int8 start_register,char * buffer, int8 count)
     int8 csum=0;
     i2c_start();
     i2c_write(CHIP_ADDRESS);
     i2c_write(start_register);
     i2c_start();//repeated start
     i2c_write(CHIP_ADDRESS | READ); //read
     while(count--)
         *buffer=i2c_read();
         csum ^= *buffer;
         buffer++;
     } //note chip does not require a NACK
     i2c_stop();
     i2c_start();
     i2c_write(CHIP_ADDRESS | READ); //now read checksum
     csum ^= i2c_read();
     i2c_stop();
     return csum; //returns 0 if checksum OK
This transfers 'count' bytes into the buffer, starting at 'start_register', and returns 0 if the checksum matches.
