Are you using just the raw chip or a premade PCB module? I'll assume the latter as it needs a very skilled tech to design and fab a working PCB! Post the link to the module you're using as well as which PIC you think you can use.
The more information you supply the faster/better the replies you'll get.
Code block added.
- Forum Moderator
Posted: Tue Oct 13, 2015 3:26 am
1) Use the code buttons.
2) Does the 'pre-made module' have a data sheet?. This is _vital_ It'll tell you/us, things like how pin 57 is wired (changes the I2C address), how the interfacing is actually done, etc. etc..
DATA
DATA
DATA
The three most important things _before_ starting a project.....
