Int rda problem
art
Int rda problem
PostPosted: Sun Sep 20, 2015 8:26 pm     Reply with quote
Hi, i'm trying to use int_rda function to exit ADC loop , but its not working. Whats wrong with my code?
Here is my code:
#include <18F4550.h>
#DEVICE ADC=10
#use delay(clock=20000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#int_rda
void rx_isr()
char c;
c=getc();
if(c=='Y')
{break;}
 main()
   float min, value;
   int8 binary_string[10];
   char ch;
   printf("Enter "Z" for ADC or "z" for binary number : \n");
        if(ch=='x')
        return(0);
        switch(ch)
case 'Z':
    enable_interrupts(INT_RDA);
    setup_port_a(ALL_ANALOG);
    set_adc_channel(0);
    do  {
                  value = Read_ADC();
                  min=value*5/1023;
                  printf(" Voltage : %2.3f V   NO: %3.0f ", min);
            }while(TRUE);
case 'z':
   while(true)
               printf("Enter 8 binary number : \n");
               get_string(binary_string,9);
                     if(binary_string=='A')
                       {break; }
               output_D((int8)strtoul(binary_string,0,2));
PostPosted: Mon Sep 21, 2015 12:27 am     Reply with quote
Layout your brackets logically, and the first fault becomes obvious:
#int_rda
void rx_isr(void)
   char c;
   c=getc();
   if(c=='Y')
////Duh. Where is the terminating bracket for the interrupt handler.....
In fact the 'break' does nothing. The code always exits for every character...
You need to set a flag to say "I have a 'Y'", and then test for this in the main. The logic is flawed.
art
PostPosted: Mon Sep 21, 2015 1:00 am     Reply with quote
Dear ttelmah,
Can you show the code how to put 'Y' flag. Please...i really don't have idea.
art
PostPosted: Tue Sep 22, 2015 12:01 am     Reply with quote
I have modified the code, but when i type 'Y' , " ADC STOP " not appear. The code can be compile. What should i do?
#DEVICE ADC=10
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
#int_rda
void rx_isr()
char c;
c=getc();
 main()
   float min, value;
   char ch;
        if(ch=='x')
        return(0);
        switch(ch)
case 'Z':
    set_adc_channel(0);
    do  {
                  value = Read_ADC();
                  min=value*5/1023;
                  if((int_rda)=='Y')
                  printf(" ADC STOP \n");
            }while(TRUE);
case 'z':
   while(true)
                       {break; }
ezflyr
PostPosted: Tue Sep 22, 2015 5:51 am     Reply with quote
Do you have real hardware, or is this a Proteus exercise?
It's pretty clear from your program structure that you've done no troubleshooting! My advice is to greatly simplify your program to the point that you can receive and display individual characters. Only then should you attempt to make conditional decisions based on what you receive!
John
PostPosted: Tue Sep 22, 2015 7:00 am     Reply with quote
switch(ch)
Take a look at the "ch" variable listed in the switch. Where do you set the ch variable? Does it have a known value in it? It's not the same as you interrupt's variable. I don't think your switch is gonna work.
if((int_rda)=='Y')
This isn't valid. "int_rda" isn't a variable. You need to rethink this.
art
PostPosted: Tue Sep 22, 2015 5:40 pm     Reply with quote
Hi jeremiah,
I have test this code using real hardware. The switch(ch) is functioning. The only problem i cannot exit the adc loop.
       ch=getc();
        if(ch=='x')
        return(0);
        switch(ch)
Sorry for mistyping.
guy
PostPosted: Sun Sep 27, 2015 1:55 pm     Reply with quote
#DEVICE ADC=10
#include <string.h>
#include <input.c>
#include <stdio.h>
#include <stdlib.h>
char newCh=0;   //// global variable - accessible from ISR and Main
#int_rda
void rx_isr()
newCh=getc();      //// store new char in newCh
 main()
   float min, value;
   char ch;
        if(ch=='x')
        return(0);
        switch(ch)
case 'Z':
    set_adc_channel(0);
    do  {
                  value = Read_ADC();
                  min=value*5/1023;
                  if(newCh=='Y')             //// check global variable
            }while(TRUE);
case 'z':
   while(true)
                       {break; }
ezflyr
PostPosted: Sun Sep 27, 2015 4:55 pm     Reply with quote
Just out of curiosity, what do you guys, art & guy, think this line does:
Return(0);
John
guy
PostPosted: Mon Sep 28, 2015 1:20 am     Reply with quote
Return(0) is not recommended in main() Cool Nowhere to return to.
Art's question was: The only problem i cannot exit the adc loop. I tried to help him with his problem.
art
PostPosted: Mon Sep 28, 2015 2:26 am     Reply with quote
Dear guy,
Thank you for your code. It works.
