error 66 compile problem pointer
sebalitter
PostPosted: Tue Aug 25, 2015 1:33 pm     Reply with quote
Hello there is an error in this code.
"*** Error 66 "main.c" Line 108(39,43): Previous identifier must be a pointer"
PIC18F46K20
MPLAB X 3.0v
CCS 4.130v
can you help me?
thanks!
// defined(__PCH__)
//#include <18F452.h>
#include <18F46K20.h>
#include "string.h"
#use delay(clock=10000000)
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, BITS=8, PARITY = N,ERRORS, stream=PC)
//definiciones del Programa
#define LEDRojo1 PIN_A0     //anodo1 del led rojo
#define LEDRojo2 PIN_A1     //anodo2 del led rojo
#define LEDVerde1 PIN_C2    //anodo2 del led rojo
#define LEDVerde2 PIN_C3    //anodo2 del led rojo
#define SENSOR PIN_A2
#define FOTO PIN_E0     //RELE para la camara de fotos
#define k 0.022         //constante para cambio de unidades  (Km/hora, M/seg, etc)
#define LOW 0
#define HIGH 1
#define INTS_PER_SECOND 10         // (10000000/(4*4*65536))
//funciones prototipo
byte Selecciona( char, int);
//Variables globales
char palabra[14];// = "PROMETEC.NET  " ;
int num=0, len=0, fil=0;
float tiempo=1, medicion=0;  //tiempo entre cada medicion. Debe ser menor o igual a 1 segundo
//long rise,fall,pulse_width,count=0;
byte F;
int seconds;      // A running seconds counter
int int_count;    // Number of interrupts left before a second has elapsed
const byte P[8] = { 0x78, 0x44, 0x44, 0x78, 0x40, 0x40, 0x40, 0x40 };
const byte R[8] = { 0x78, 0x44, 0x44, 0x78, 0x70, 0x58, 0x4C, 0x46 };
const byte O[8] = { 0x3C, 0x42, 0x42, 0x42, 0x42, 0x42, 0x42, 0x3C };
const byte M[8] = { 0x66, 0x7E, 0x5A, 0x42, 0x42, 0x42, 0x42, 0x42 };
const byte E[8] = { 0x7C, 0x40, 0x40, 0x78, 0x78, 0x40, 0x40, 0x7C };
const byte T[8] = { 0x7E, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18, 0x18 };
const byte C[8] = { 0x7c, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x7C };
const byte N[8] = { 0x42, 0x62, 0x72, 0x5A, 0x4E, 0x46, 0x42, 0x42 };
const byte dot[8]={ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x06 };
const byte sp[8]= { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
#int_timer1                        // This function is called every time
                                         // timer 1 overflows (65535->0), which is
void  TIMER1_isr(void)
{                                   // approximately 19 times per second for
    if(--int_count==0) {           // this program.
      ++seconds;
      int_count = INTS_PER_SECOND;
      fil++;
    SET_TRIS_B( 0xFF ); // pone B0, B1, B2 , B3 B4, B5, B6 y B7 como salidas
    setup_timer_1(T1_INTERNAL | T1_DIV_BY_4);
    set_timer1(0);
    strcpy(palabra,"TEMPOME  ");
    len = strlen(palabra); // Calcula la longitus de s
    while(num < len)
        F = Selecciona( palabra[num], fil);
        output_B(F);
        if(fil % 8 == 1)
            num++;
byte Selecciona( char c, int fila)
    if ( c == 'P')          return( P[fila]) ;
    if ( c == 'R')          return( R[fila]) ;
    if ( c == 'O')          return( O[fila]);
    if ( c == 'M')          return( M[fila]);
    if ( c == 'E')          return( E[fila]);
    if ( c == 'T')          return( T[fila]);
    if ( c == 'C')          return( C[fila]);   // problem
    if ( c == 'N')          return( N[fila]);
    if ( c == '.')          return( dot[fila]);
    if ( c == ' ')          return( sp[fila]);
asmboy
PostPosted: Tue Aug 25, 2015 2:04 pm     Reply with quote
C[[color=orange]fila[/color]]);   // problem
i quite agree with the compiler.
this does not compile "above the neck" for me either.
what do you intend? Sad Shocked
sebalitter
PostPosted: Tue Aug 25, 2015 2:08 pm     Reply with quote
I was trying to remark the problem in this forum.
PostPosted: Tue Aug 25, 2015 2:13 pm     Reply with quote
PASS_STRINGS="IN_RAM"
Otherwise a pointer cannot be constructed to a const.
A search here will find all about this, and several explanations of 'why' (down to the actual architecture of the PIC).
I'd have expected it to error earlier, but the error locations given by the compiler are often 'strange'....
