How to separate math routines?
E_Blue
PostPosted: Thu Aug 06, 2015 9:52 am     Reply with quote
There's any way to have separate math routines for INTs and Main code?
Electric Blue
PostPosted: Thu Aug 06, 2015 10:01 am     Reply with quote
Not too sure what you mean, so please provide an example program that show us. The more you explain the easier and faster we can help.
Also, I'm assuming INTs means Interrupt Service Routines ?
Hmm, which 'math' routines ? If it's simple code, it'd be inline, complex then callable as it becomes more efficient in code space and time.
PostPosted: Thu Aug 06, 2015 10:07 am     Reply with quote
See this thread and the links in it.
http://www.ccsinfo.com/forum/viewtopic.php?t=42118
E_Blue
PostPosted: Thu Aug 06, 2015 12:07 pm     Reply with quote
@temtronic
I need to use 16bit division and multiplication inside interrupts and in the Main code.
@PCM programmer
I read an tried #org and compile, but the message
Interrupts disabled during call to prevent re-entrancy:
still appear.
I do something like
#include <18F67J50.h>
//Several variables definition
#include <Config.h>
#include <usb_cdc.h>
#include <stdlib.h>
// Includes all USB code and interrupts, as well as the CDC API
#include <string.h>
#include <strings2.h>
#include "25LC256.h"
#include "Bits_Rules.h"
//Few prototypes
#org 0x1FF, 0x8000
//Here start all the subroutines and functions that are called by different interrupt handlers
////Some 16 bit division and multiplication here
void CountData()// <---This routine is called from Main once at start and from one interrupt handler
#org DEFAULT
void Main (void)
//Some 16 bit division and multiplication here too
I tried to putt #org DEFAULT before CountData() too and get the same Warning.
So I think is not working, I don't end to understand how #org works.
What I'm doing wrong? Question
Electric Blue
PostPosted: Thu Aug 06, 2015 1:59 pm     Reply with quote
The USB code contains one 16bit multiplication. So it'll still give the error.
They accept it, since on a PIC18, it uses the hardware multiplier and is only a handful of instruction times.
So I'd not worry about multiplication, but division really should be avoided, just on the grounds of time.
E_Blue
PostPosted: Thu Aug 06, 2015 2:39 pm     Reply with quote
I'm not receiving warnings about math yet, I'm asking before implement it to know hot to proceed.
This are all the warning for the current version
>>> Warning 216 "GPRS_2.c" Line 11917(1,2): Interrupts disabled during call to prevent re-entrancy: (ReadByteEE)
>>> Warning 216 "GPRS_2.c" Line 11917(1,2): Interrupts disabled during call to prevent re-entrancy: (FillBufferEE)
>>> Warning 216 "GPRS_2.c" Line 11917(1,2): Interrupts disabled during call to prevent re-entrancy: (@PSTRINGC_1801)
>>> Warning 216 "GPRS_2.c" Line 11917(1,2): Interrupts disabled during call to prevent re-entrancy: (usb_token_reset)
>>> Warning 216 "GPRS_2.c" Line 11917(1,2): Interrupts disabled during call to prevent re-entrancy: (SaveTime)
>>> Warning 216 "GPRS_2.c" Line 11917(1,2): Interrupts disabled during call to prevent re-entrancy: (usb_cdc_flush_tx_buffer)
>>> Warning 216 "GPRS_2.c" Line 11917(1,2): Interrupts disabled during call to prevent re-entrancy: (usb_tbe)
>>> Warning 216 "GPRS_2.c" Line 11917(1,2): Interrupts disabled during call to prevent re-entrancy: (usb_cdc_get_discard)
>>> Warning 216 "GPRS_2.c" Line 11917(1,2): Interrupts disabled during call to prevent re-entrancy: (CountData)
ReadByteEE, FillBufferEE,,SaveTime and CountData are subroutines and functions maked by me, the rest are from CCS USB library.
Electric Blue
PostPosted: Fri Aug 07, 2015 2:29 am     Reply with quote
Yes. These routines are basically 'initialisation'. So (for instance) the routine that clears the buffer is only called in the main code, when USB first wakes. Hence there is no loss really in having interrupts disabled during it. It's used in the interrupts when a bus reset has to take place. You can simply duplicate it if required, but it gains nothing to do so.
I'd worry about anything involving 'EE' in an interrupt though. Given the milliseconds most types of electrically erasable memory take, that has alarm bells ringing....
