Output B problem
art
Output B problem
PostPosted: Sun Aug 02, 2015 6:18 pm     Reply with quote
Hi, i would like to send my input character to output_B. If i type in '00000111' why output B cannot show binary 00000111 ?
Below is my code:
#include <18F452.h>
#use delay(c20000000000)
#include <stdio.h>
#include <string.h>
char x[8];
while(true)
      printf("Enter number:  \n");
      get_string(x,8);
       output_B(0bx)
PostPosted: Sun Aug 02, 2015 11:57 pm     Reply with quote
1. Your array is too small for the whole string. A string always has a 0x00
byte at the end. This requires a 9-element array.
2. output_b() doesn't take a string as the parameter. It takes an integer.
This is in the CCS manual.
3. You need a routine to convert an ascii binary string to an integer.
CCS doesn't have one, so I have provided it below. The routine is
called abtoi(). It means "ascii binary to integer".
#include <16F887.h>
#fuses INTRC_IO, NOWDT
#use delay(clock=4M)
#include <stdlib.h>
int8 binary_string[9];
int8 abtoi(char *ptr)
long retval;
char c;
char i;
retval = 0;
for(i = 0; i < 8; i++)  // Read up to 8 characters
    c = *ptr++;    // Read char from string
    if(c < '0')    // Test if it's an ascii binary value
       break;      // If not, we are done
    if(c > '1')
    retval <<= 1;   // Shift left by 1
    if(c == '1')
       retval |= 1;
return(retval);
int8 result;
strcpy(binary_string, "00000111");
result = abtoi(binary_string);
printf("result = %u \r", result);
while(TRUE);
art
PostPosted: Mon Aug 03, 2015 1:00 am     Reply with quote
Thank you for your reply. If i want to send result to port b, is it :
output_B(result);
Kindly please reply.
PostPosted: Mon Aug 03, 2015 1:25 am     Reply with quote
Get the string. Then do this:
output_B(result);
PostPosted: Mon Aug 03, 2015 1:59 am     Reply with quote
As a comment, 'C' does have a binary to integer function. So you can do the conversion using:
#include <16F887.h>
#include <stdlib.h>
#include <input.c> //This is what contains the get_string function
#include <string.h>
int8 binary_string[10];
   while (TRUE)
      get_string(binary_string,9);
      output_B((int8)strtoul(binary_string,0,2));
The 'downside', is that because this is a 'universal' function, it probably results in bulkier code (though the compiler optimiser is quite good).
It says convert the string, up to the first non numeric character into an unsigned long integer. Any remaining characters would be stored at the location given by the second argument (0 says to ignore these), and to convert the number from base 2 (that's what the '2' says).
I then cast this to an int8 (not really necessary, but I tend to play safe...).
art
PostPosted: Mon Aug 03, 2015 4:30 am     Reply with quote
Thank you very much both of you for solving my problem.
