help me with this code
micro17
PostPosted: Sun Aug 02, 2015 11:32 am     Reply with quote
Hi all
Please help me with this code, work in proteus but in breadboard not....the LED only stay bright/ON
Thank you
      LED on gpio.1 blinks at rate controlled by
      potentiometer connected to gpio.0
 #include <12f683.h>
 #device adc=10
 #use delay(clock=8000000)
 #fuses nowdt,intrc_io,put,noprotect,brownout,nomclr,nocpd
 #define LED PIN_A1                // define pin for LED
    int16 ad = 0;                  // holds 10-bit a/d value 0 to 1023
 void init(void)                   // hardware initialization
    output_low(LED);               // LED off on boot
    set_tris_a(0x01);              // gpio.0 input, rest outputs
    setup_oscillator(OSC_8MHZ);    // set for 8MHz internal osc
    setup_adc_ports(AN0_ANALOG);   // a/d enabled on gpio.0
    setup_adc(ADC_CLOCK_DIV_16);   // a/d clock /16 @8MHz,Tad=2uS
    setup_comparator(NC_NC_NC_NC); // disable comparator module
 void Blink(int16 adval)
    int16 rate;
    rate=adval*2;       // ~0-2Hz blink rate
    output_high(LED);   // LED on.  gpio.1 o--/\/\/\---|>|---o gnd
    delay_ms(rate);     // blink delay         330     LED
    delay_ms(rate);     // delay before return
    init();             // configure hardware
    while(1)            // continuous loop
     set_adc_channel(0);// set a/d channel to gpio.0
     delay_us(50);      // delay for acquisition
     ad = read_adc();   // read a/d into ad variable
     Blink(ad);         // blink LED at rate set by 10-bit a/d value
 /******************* The End ********************/
PostPosted: Sun Aug 02, 2015 12:06 pm     Reply with quote
Have you actually checked your chip is running?.
Also have you double checked there isn't something like a short somewhere?.
micro17
PostPosted: Sun Aug 02, 2015 12:08 pm     Reply with quote
yes 300 ohm resistor
I try 5k and 10 k pot
PostPosted: Sun Aug 02, 2015 12:12 pm     Reply with quote
You say 330 in the comments.. Smile
Saw this after I originally posted, edited the post to remove this, but you had replied already.
What compiler version?.
micro17
PostPosted: Sun Aug 02, 2015 12:16 pm     Reply with quote
not have 330 ohm Smile
PCWHD 5.042
micro17
PostPosted: Sun Aug 02, 2015 1:07 pm     Reply with quote
work...bad connection on pot, solved
Thank you, Ttelmah
