pic 24 external interupts [solved ]
smee
PostPosted: Wed Jul 29, 2015 7:17 am     Reply with quote
hi everyone,
i am using pcd 4.120 with pic24fj256gb210.
i am wanting to use external interupts 0,1,2,3,4
i have no problem with external interupts 2,3,4 and the
pin_select int2=pin_xx
pin_select int3=pin_xx
pin_select int4=pin_xx
functions as it should.
but i keep getting
Invalid Pre-Processor directive Invalid Pin ID
for the lines that contain
#pin_select int0=pin_xx
#pin_select int1=pin_xx
has anyone got any idea how i work around this - i cant figure a way round this one.
PostPosted: Wed Jul 29, 2015 8:19 am     Reply with quote
Read the data sheet.
INT0 is hardwired to pin D0. Not a selectable peripheral.
INT1 should work, I'd suspect a compiler issue. 4.120, is a relatively early compiler for this chip.
