Timer0 doesn’t seem to count external pulses
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Mon Jul 27, 2015 2:19 pm     Reply with quote
Folks,
I’m trying to use the Timer0 as a tachometer to keep track of a fan. I can see the square wave on the RA4/T0CKI pin with the oscilloscope. But the counter doesn’t seem to be incrementing.
Fuses:
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
Timer0 setup
setup_timer_0(RTCC_EXT_H_TO_L | RTCC_DIV_1);    // Fan tachometer
setup_timer_1(T1_INTERNAL | T1_DIV_BY_8);       // control loop pace
setup_timer_2(T2_DISABLED,0,1);                 // PWM will be derived from Timer2
setup_oscillator(OSC_8MHZ);
Timer0 interrogation
output_high(FAN_ON);                      // turn on the fan
delay_ms(1000);                           // give some time for the fan to spin up
set_timer0(0);                            // zero the counter
delay_ms(1000);                           // allow time to accumulate counts
output_low(FAN_ON);                       // turn off the fan
if ( get_timer0() == 0 ) {
   return FAN_STUCK;                      // the code gates here when fan is spinning and tachometer is pulsing (approx 120 - 130 Hz)
No ISR for Timer0 .
Am I missing something?
Cheers,
- Nick
PIC18F4550
4.081
Read the label, before opening a can of worms.
kender
PostPosted: Mon Jul 27, 2015 2:28 pm     Reply with quote
Nevermind. It was a hardware problem. Nothing wrong with my timer code.
You, folks, are always an inspiration.
PostPosted: Mon Jul 27, 2015 2:31 pm     Reply with quote
More to the point, I suspect your 'posting the question', made you look again. This has been mentioned recently. It's surprising how often it works!.
At least for you it did. Laughing
