Cannot use Interrupt-on-change PIC16F1459
kokabt
PostPosted: Mon Jul 27, 2015 3:35 am     Reply with quote
I'm working a program on PIC16F1459 and i need to use interrupt on change.
Can please somebody help me why when i compile my program there is an error message: Invalid pre-processor directive on the line #INT_RB6_L2H. When i try to use other interrupts(example: INT_TIMER0) there is no error.
Thank you in advance. Confused
PostPosted: Mon Jul 27, 2015 8:13 am     Reply with quote
No, it's a case of not quite understanding the chip, and how CCS handles it.
There is _not_ an interrupt 'INT_RB6_L2H'. There is a single #INT_RB (for all changes on port B), which can be programmed to only happen on pin RB6 changing from low to high.
So they are used like:
#INT_RB  //The handler is always just INT_RB
void  RB_isr(void)
   enable_interrupts(INT_RB6_L2H); //enable INT_RB to only sense RB6 low to high
You can't use the 'configuration' names, as names for the interrupt handler.
Separately, you may also have to manually clear the IOCBF register. This depends on the age of the compiler. The current ones do this for you, older versions in some cases do not. A search here will find code for this.
kokabt
PostPosted: Mon Jul 27, 2015 8:55 am     Reply with quote
Thank you Ttelmah,
now I understand. Your way works excellent.
