bcfd36
Joined: 14 Apr 2015 Posts: 28 Location: Boulder Creek, CA
| Opinion on "Master and Command C for PIC® MCU" by |
Posted: Mon Jun 01, 2015 12:04 pm |
Have any of you used or even looked at "Master and Command C for PIC® MCU" by Fred Eady? As should be obvious from some of my questions, I am quite new to PICs but have 30+ years of C. Actually, closer to 40, off and on. I am looking for tips and tricks and techniques. Then maybe I can quit bugging you guys. For that matter, can you recommend anything in addition to or in place of the above?
I ordered the Mark Siegesmund book, but then it occurred to me that there were people that might have some good input. Hence, my question. _________________ D. Scruggs |
bcfd36
Posted: Mon Jun 01, 2015 2:29 pm |
Thanks, I will take a look at it. _________________ D. Scruggs |
Posted: Tue Jun 02, 2015 2:00 am |
Funnily enough, whatever else you have, make sure you have a copy of K&R.
CCS C, keeps _very_ close to the original K&R syntax (more so than many 'later' C's). Once you have done the initial setups (processor, fuses, clock etc.), stuff that is in the original K&R book, will generally compile 'as is' in CCS.
The point about the add-on books is that they help with understand those setup bits, and the differences involved in working with the PIC hardware, but as a basic reference, K&R, should be considered the bible.  |
