how to add dead band delay with half bridge PWM with ccsc 5
wings1122
PostPosted: Wed May 27, 2015 2:31 pm     Reply with quote
i am the newer of ccsc with PIC, i would like to generate a half bridge PWM driver for test, but I dont know how to setup the dead band delay on ccsc. Could any help
#include <18F4550.h>
#device ADC=16
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(clock=48MHz,crystal=20000000)
#define LED PIN_B7
#define DELAY 50
#include <main.h>
   setup_timer_2(T2_DIV_BY_1,1,1);      //0.2 us overflow, 0.2 us interrupt
   setup_ccp1(CCP_PWM|CCP_PWM_HALF_BRIDGE|CCP_SHUTDOWN_AC_L|CCP_SHUTDOWN_BD_L);
   set_pwm1_duty((int16)4);
   //Example blinking LED program
   while(true)
      output_low(LED);
      delay_ms(DELAY);
      output_high(LED);
      delay_ms(DELAY);
PostPosted: Wed May 27, 2015 2:49 pm     Reply with quote
add CCP_DELAY to your declaration, and put the value into the ECCP1DEL register. It's not explained properly, but this is the value that can optionally be placed _after_ the mode settings.
PostPosted: Wed May 27, 2015 10:14 pm     Reply with quote
If I compile your posted program with vs. 5.046, the compiler sets the deadband delay to 0, as shown below in the .LST file:
....................    setup_ccp1(CCP_PWM|CCP_PWM_HALF_BRIDGE|CCP_SHUTDOWN_AC_L|CCP_SHUTDOWN_BD_L);
0046:  BCF    TRISC.TRISC2
0048:  BCF    LATC.LATC2
004A:  BCF    TRISD.5
004C:  MOVLW  8C
004E:  MOVWF  CCP1CON
0050:  [b]CLRF   ECCP1DEL[/b]  // Set deadband delay to 0
0052:  CLRF   ECCP1AS
The CCS manual says this:
setup_ccp1 (mode, pwm)
pwm parameter is an optional parameter for chips that includes ECCP module. This parameter allows setting the shutdown time. The value may be 0-255.
But if I do this (with a parameter of 5, for example), I get code that sets
the ECCP1DEL register to 5. This is the deadband delay register.
.................... setup_ccp1(CCP_PWM|CCP_PWM_HALF_BRIDGE|CCP_SHUTDOWN_AC_L|CCP_SHUTDOWN_BD_L, 5);
004A: BCF TRISD.5
004C: MOVLW 8C
004E: MOVWF CCP1CON
0050: MOVLW 05 // Set deadband delay to 5
0052: MOVWF ECCP1DEL
0054: CLRF ECCP1AS
I submit that the CCS manual is wrong, and that the 2nd parameter is
really the deadband delay. I am going to email them about this right now.
PostPosted: Thu May 28, 2015 8:23 am     Reply with quote
Totally agree.
I did say "It's not explained properly, but this is the value that can optionally be placed _after_ the mode settings."
It has been mentioned here in the past in another thread, which is why I knew it was this value.
wings1122
PostPosted: Fri May 29, 2015 11:30 am     Reply with quote
thank you all.
