Current Time from PC
MarkchchPIC
PostPosted: Mon May 25, 2015 5:09 pm     Reply with quote
Hi All, Is there a way to use the __TIME__ function of the compiler to extract the current time and use the data to set up say a DS1307?
PostPosted: Mon May 25, 2015 6:51 pm     Reply with quote
It only works at compile time. It doesn't work at runtime. And indeed at
runtime, you would need some connection between the PIC and a PC to
get the time by any method.
MarkchchPIC
PostPosted: Mon May 25, 2015 8:19 pm     Reply with quote
Thanks PCM,
So if I have a serial connection to the PC I could setup and send a string in the format hhmmss then read at the PIC and update the DS1307?
PostPosted: Mon May 25, 2015 9:32 pm     Reply with quote
Of course, but the compiler won't do that for you. You have to write a PC program to send the current time as a string when prompted or maybe once per minute. Or maybe you can find a freeware program that does that.
Either way, that's only half the battle. You'd also need to add PIC code to a) catch the string, b) parse/interpret the string, and c) properly write present time to the DS1307.
