Remco
| No UART interrupt |
Posted: Tue May 12, 2015 1:55 am |
Hello people of the CCS community,
Recently I started using the CCS compiler as a trainee at a company. But I think I found a problem. When I want to use the hardware UART of the device(dsPIC30F6014A) it doesn't work on interrupt base. I tried to read the UART manually and it worked. Therefore I think it might be the interrupt handling. I have also looked at other code for another UART interrupt on a different device (18F6620). The interrupt for this device works perfect. Therefore I went deeper in the code and ended in the .lst file. In this file I found the difference between a working and none working UART interrupt. Following is the code I came across:
18F6620:
| Code: | #include <18F6620.h> //or 18F6620 for double program space
#fuses HS,NOWDT
#device ADC=10 //Set to 10bits AD converter
#use delay(clock=20M,crystal,RESTART_WDT)
#use rs232(baud=9600, XMIT=PIN_C6, RCV=PIN_C7,STREAM=HOST,ERRORS, TIMEOUT = 20) //setup serial. |
This code results in the following in the list file:
.................... #use rs232(baud=9600, XMIT=PIN_C6, RCV=PIN_C7,STREAM=HOST,ERRORS, TIMEOUT = 20) //setup serial.
035A2: MOVLW 40
035A4: MOVLB 1
035A6: MOVWF x18
035A8: CLRWDT
035AA: MOVLW 02
035AC: MOVWF x19
035AE: MOVLW 9A
035B0: MOVWF x1A
035B2: MOVLB 0
035B4: BRA 357E
035B6: MOVLB 1
035B8: DECFSZ x19,F
035BA: BRA 35AE
035BC: DECFSZ x18,F
035BE: BRA 35C6
035C0: CLRF 1D
035C2: CLRF 01
035C4: BRA 35DA
035C6: BTFSS F9E.5
035C8: BRA 35A8
035CA: MOVF FAB,W
035CC: MOVWF 1D
035CE: MOVF FAE,W
035D0: MOVWF 01
035D2: BTFSS 1D.1
035D4: BRA 35DA
035D6: BCF FAB.4
035D8: BSF FAB.4
035DA: MOVLB 0
035DC: GOTO 35E6 (RETURN)
As far I can see this is a good code for hardware UART with interrupt (which works). The following is the code for the dsPIC30F6014A:
#include <30F6014A.h>
#device ADC = 12 //Set to 12bits AD converter
#fuses HS, NOMCLR, PUT64, NOWDT
#use delay (clock = 20M, CRYSTAL, RESTART_WDT)
#use rs232 (UART2,BAUD = 9600, ERRORS, STREAM = UART_MASTER)
.................... #use rs232 (UART2,BAUD = 9600, ERRORS, STREAM = UART_MASTER)
There is no assembly code showing as it did in the example for the 18F6620. Could this be the problem why my UART interrupt doesn't work?
An additional test I had performed is to convert to a software UART, I know this doesn't generate any interrupt but I want to know if it would change the code in the lst file for the UART. And it did change when I converted it to a software UART. This was for both metthods (FORCE_SW, and selecting hardware UART with UART1 but change the RX an TX pin to a none hardware UART).
If someone had the same problem or know the solutions please help me.
This isn't my first programming project and I already "master" different program languages therefore it's really bothering and annoying me and I'm eager to know/learn to solution.
Kind regards,
Remco
ps: If you want more information, please ask I'm happily to provide it. |
Posted: Tue May 12, 2015 2:42 am |
Start at the beginning. CCS generally _does not_ show it's own routines in the listing.
This is controlled by the line #NOLIST at the start of the processor include file. At some point, somebody has removed this (probably remmed it out), for your 6620 chip, so the listing is there. Do the same for your DSPIC and the listing will appear.
This is done because when you are debugging _your_ code, having dozens of bits of CCS code shown can be confusing.
Always what you post should be a small complete program that shows the problem. Currently we can't compile your code without a lot of guessing as to the missing bits. Something like:
#FUSES NOWDT
#FUSES CKSFSM
#FUSES BROWNOUT
#FUSES BORV42
#FUSES NOMCLR
#FUSES HS
#FUSES NODEBUG
#device ICSP=1
#use delay(crystal=20M)
#use rs232(UART2, BAUD=9600, ERRORS, BRGH1OK, STREAM=UART_MASTER)
int1 have_data=FALSE;
int8 chr;
#INT_RDA2
void RX2_int(void)
//crude test for RX2 interrupt
chr=fgetc(UART_MASTER);
have_data=TRUE;
int8 local;
delay_ms(100); //allow time for RS232 buffers to settle
clear_interrupt(INT_RDA2);
enable_interrupts(INT_RDA2);
//enable serial interrupt on UART2
do
if (have_data)
//interrupt has occured
local=chr;
have_data=FALSE;
//Now toggle an output to show the interrupt has happened
//and send the inverted character back
fputc(local ^ 0xFF, UART_MASTER);
output_toggle(PIN_B15);
} while (TRUE);
As comments, get rid of restart_wdt. Since you don't have the watchdog enable, 'pointless', and if you were using the watchdog for real, also pointless!....
generally to use the watchdog properly, it must _only_ be restarted, when the code is properly running. Have 'compiler generated' restarts put into bits of the code where the chip could be hung, completely destroys the point of the watchdog....
Using timeout with the interrupt is also pointless. Using the serial interrupt, you should _only_ be reading characters when the interrupt occurs to say 'there is a character'.
Then repeat three times 'what compiler version'.... |
Remco
Posted: Tue May 12, 2015 3:50 am |
Ttelmah,
Thank you for your quick reaction. but in the mean time I was trying to get it to work, and I did it. I don't know how but that's I would say usual. But I little at the #NOLIST command. This command only make the C code in the .lst file invisible. This code was not implemented in my code. However thank you for your reaction. I hope this UART interrupt would last by now I hope.
Kind regard,
Remco |
Posted: Tue May 12, 2015 9:44 am |
The compiler doesn't generate code unless you use it or there are some special preprocessor directives used to force it (like the #int_xxx for example).
It's possible you had a mistake in your code that made the compiler think you were never gonna call the function, so it didn't generate code for it. |
