Brain teaser in the March 2015 CCS PCM User manual
asmboy
PostPosted: Thu May 07, 2015 5:51 pm     Reply with quote
I had to read the syntax guidance several times to realize what i was seeing in the wild land of transposed characters on the Zero Cross Detector
rollup support in the compiler.
Hilarious if not so unfortunate
Confused
setup_zdc( )
Syntax: setup_zdc(mode);
Parameters: mode- the setup of the ZDC module. The options for setting up the module include:
 ZCD_ENABLED
 ZCD_DISABLED
 ZCD_INVERTED
 ZCD_INT_L_TO_H
 ZCD_INT_H_TO_L
Returns: Nothing
Function: To set-up the Zero_Cross Detection (ZCD) module.
Availability: All devices with a ZCD module.
Examples: setup_zcd(ZCD_ENABLE|ZCD_INT_H_TO_L);
Example Files: None
Also See: zcd_status()
and this:
zdc_status( )
Syntax: value=zcd_status()
Parameters: None
Returns: value - the status of the ZCD module. The following defines are made in the device's
header file and are as follows:
 ZCD_IS_SINKING
 ZCD_IS_SOURCING
Function: To determine if the Zero-Cross Detection (ZCD) module is currently sinking or sourcing current.
If the ZCD module is setup to have the output polarity inverted, the value return will be reversed.
Examples: value=zcd_status():
Also See: setup_zcd()
Confused
PostPosted: Thu May 07, 2015 7:40 pm     Reply with quote
hmm.. seems 'normal' to me.....
then again I've got a half dead left ring finger so typing has been a 'challenge' so I kinda like 3 letter variables.
ZCD is a lot easier than Zero_cross_detector
I can see how zdc znd zcd can be typed !!
yeah, I spell my name wrong too soemtimes.
