problem concerning time cost of every instruction
balboa
PostPosted: Sat Apr 25, 2015 1:35 pm     Reply with quote
hey there :
I haven't decided which PIC to work with yet but my project works in real time and I need to know how much each CCS PIC C instruction takes in time ?
help pls Sad
PostPosted: Sat Apr 25, 2015 1:48 pm     Reply with quote
Not possible to answer.
Do a search here, this has been discussed before.
A CCS instruction can be anything from one machine instruction, to tens of thousands. The same instruction can use different amounts of time dependent on the variables involved. Then the optimiser may change that actual code used dependent on the actual values involved.
You have to benchmark your code, either using something like MPLAB simulator, or physically using marker pulses, and a scope/logic analyser.
PostPosted: Sat Apr 25, 2015 2:51 pm     Reply with quote
How to use the Stopwatch feature of MPLAB (vs. 8.92) simulator to
find the number of instruction cycles in a segment of your program:
http://www.ccsinfo.com/forum/viewtopic.php?t=38351
PostPosted: Sat Apr 25, 2015 3:37 pm     Reply with quote
I prefer the 'old school' method where you dump the listing of your program and go though it line by line.
If you're using a 16 series PIC at 4 MHz, each instruction will take 1us. Except for jumps...
If you look at the datasheet of your PIC from Microchip, it will list all the 'opcodes' and 'cycles'.
This is a GREAT way to LEARN the workings of a microcomputer....
..probably NOT taught at ANY level of school these days as all anyone does is crank up the speed to say 64MHz and then 'time' is not a factor.
balboa
thank you for help
PostPosted: Sun Apr 26, 2015 7:49 am     Reply with quote
REALLY APPRECIATE IT Smile
mbradley
PostPosted: Sun Jul 05, 2015 12:52 am     Reply with quote
I agree with temtronic, I just recently did this because I had to seriously reduce execution time down to a few cycles...
by looking at the listing, I saw I could save 4 cycles from reducing:
if (i ==4) { i = 0; }
to:
i = i & 0b0011;
As a side note, I wrapped this project up that lets me do what you need, it allows you to time functions inside your project in real time:
http://www.ccsinfo.com/forum/viewtopic.php?t=54115
Michael Bradley
www.mculabs.com
Open Drivers and Projects
