int_ext3
kishen
int_ext3
PostPosted: Fri Apr 17, 2015 9:44 am     Reply with quote
I am using port b to switch on motor for a period of time using timer. I chose port b as it has internal pull up resistors and are equipped with timer function. I have written a code that has two push buttons, pin_b0 and pin_b1 using int_ext, int_ext1. The problem is i want to use 6 push buttons. I tried int_ext3 but i don't know which pin it enables. Please help me for the rest of 4 inputs.
Here is my code which works fine for 2 inputs:
#include <18F8722.h> //select proper pic header file
#device ICD=TRUE
#fuses HS,NOLVP,NOWDT
#use delay (clock=20000000)
int i=0;
int j=0;
int k=0;
#INT_TIMER0
void interrupt_tim0() // program automatically jump on ISR when overflow occurred
i++;
if(i==3 & j==1) // check for about 5 sec
   output_high(PIN_J6);  // Off the motor again after 5 sec
   output_high(PIN_J4);
   i=0;
   j=0;
   disable_interrupts(INT_RTCC);//disable timer0
  } //end of ISR
if(i==5 & k==1) // check for about 5 sec
   i=0;
   k=0;
} //end of ISR
#int_ext     //Set external interrupt on pin RB0-INT0
void ext_isr() // program automatically jump on ISR when overflow occured
j=1;
enable_interrupts(INT_RTCC);//enable timer0
output_high(PIN_J6);  // ON the motor for 5 seconds, wait for Timer 0 interrupt
output_low(PIN_J4);
}//end of ISR for ext interrupt
#int_ext2     //Set external interrupt on pin RB0-INT0
void ext2_isr() // program automatically jump on ISR when overflow occured
k=1;
output_low(PIN_J6);  // ON the motor for 5 seconds, wait for Timer 0 interrupt
main()
// PWM Configurations
setup_timer_2(T2_DIV_BY_1,255,1); // Set PWM frequency
setup_ccp1(CCP_PWM); // Configure CCP1 to PWM mode
set_pwm1_duty(1023L); // default duty cycle = 100% (Half Speed)
set_tris_b(0xFF);    // Set RB0 to input, RB1-7 output
PORT_B_PULLUPS(1);   //disable internal pull-ups
ext_int_edge(H_TO_L);   // init interrupt triggering for button press
enable_interrupts(INT_EXT); //enable external interrupt
ext_int_edge(1,H_TO_L);   // init interrupt triggering for button press
enable_interrupts(INT_EXT1); //enable external interrupt
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128);//Timer 0 setup
output_high(PIN_J6);  // First Off the motor
while(1); // Wait for the interrupt
}// end of program
PostPosted: Fri Apr 17, 2015 12:45 pm     Reply with quote
According to the datasheet, INT0-INT3 are on pins B0-B3. So INT3 would be on B3
kishen
RE:
PostPosted: Sat Apr 18, 2015 6:14 am     Reply with quote
but there is no pin b3 for external connection in pic18f8722 and where should i connect the rest of the push buttons so i can use my interrupt feature.
asmboy
PostPosted: Sat Apr 18, 2015 6:44 am     Reply with quote
what does YOUR datasheet say is connected to pin # 55 ??
PostPosted: Sat Apr 18, 2015 1:06 pm     Reply with quote
I'd also have to say, consider another approach.
Using interrupts for buttons, means you need to have external circuitry to debounce the signals. Buttons in the real world, do not make nice on/off connections. Even if they work when kit is new, after a while buttons will start giving make/break/make/break/make connections, making interrupt responses unreliable. Also having loads of separate interrupt handlers is bulky code.
If you look at things handling lots of buttons they don't do this, Instead they use a timer tick to scan/read as many buttons as needed. They then have software debounce in the handler, so that the key has to remain made for perhaps two successive interrupts before being 'seen'.
Using a timer interrupt, you can have as many buttons as you have pins, just a single interrupt, and reliable handling of debounce, and even have things like key repeat if you want.
