Open SSL and AES En-/Decryption with ccs compiler
PIC24H
PostPosted: Thu Apr 09, 2015 5:42 am     Reply with quote
Hello, has anyone had experience with openssl (aes) and the ccs compiler?
Or how to include the files into the project (c code)?
I have e-mailed ccs customer support and asked them if they got a crypto library, but unfortunately they dont.
My plan is to decrypt an hex file in the bootloader (ex_pcd_bootloader.c).
But I'm figuring out how to include the openssl stuff into that project.
Any helpful advice?
PostPosted: Thu Apr 09, 2015 8:09 am     Reply with quote
Seriously, unless you have a very large PIC, forget it. I wrote a SSL library for a job, on a DsPIC and ended up using over 130K of code space for the security code....
PIC24H
PostPosted: Thu Apr 09, 2015 3:44 pm     Reply with quote
So in your opinion that doesnt make sense? Should I use the xtea encryption instead? I'm using a pic24hj256
RF_Developer
PostPosted: Fri Apr 10, 2015 1:55 am     Reply with quote
The point is that the resources required to implement such encryption schemes are greater than those PICs generally provide. Another question that has to be asked is what is the problem to which using such an encryption scheme is the solution? Does it, in fact, provide any real extra security, and at what price in terms of development time and system resources?
PostPosted: Fri Apr 10, 2015 6:31 am     Reply with quote
and particularly if he is talking about doing it in a bootloader.....
Tea, is a very good idea. The key here was that it is designed to be small. Xtea, was designed to be more secure, but came at the cost of being a little larger. However still much more 'PIC sized'.
For a bootloder in particular, if it needs great security, I have to say something is probably wrong with how it is being implemented.
