dspic33fj input capture
Mahdi
PostPosted: Tue Mar 31, 2015 8:38 am     Reply with quote
hi buddies
i want to measure duty cycle and freq of pwm signal with 1khz freq with input capture.
my code :
#include <33FJ256MC710.h>
#use delay(internal=7.37m)
#include <lcd.c>
setup_timer3(TMR_INTERNAL | TMR_DIV_BY_8);
setup_capture(3, CAPTURE_FE | CAPTURE_TIMER3);
int16 p=0;
p = get_capture(3,TRUE);
lcd_gotoxy(1,1);
printf(lcd_putc,"%lu",p);
but i have random number on lcd
iam for first to use input capture
can any one help me?
(excuse for poor english)
thank you
PostPosted: Tue Mar 31, 2015 9:18 am     Reply with quote
You have your input signal on pin70?. IC3.
Since you are using capture unit 3, this is where the input has to be.
You really should test for the capture event having happened:
   if (interrupt_active(INT_IC3))
       //This says an event has happened
       //read the captured value, and clear the interrupt
       clear_interrupts(INT_IC3);
Mahdi
PostPosted: Tue Mar 31, 2015 10:06 am     Reply with quote
thank you for reply
yes.on pin 70.pin_d10
but yet lcd show random number
#include <lcd.c>
#INT_IC3
void  ic3_isr(void)
   enable_interrupts(INT_IC3);
setup_capture(3, CAPTURE_EE | INTERRUPT_EVERY_CAPTURE | CAPTURE_TIMER3);
int16 p=0;
      clear_interrupt(INT_IC3);
a++;
lcd_gotoxy(1,1);
PostPosted: Tue Mar 31, 2015 10:43 am     Reply with quote
Remember this is a _capture_. You need:
   int16 old=0;
   //other init code etc...
    //loop etc..
          lcd_gotoxy(1,1);
          printf(lcd_putc,"%lu",p-old);
          old =p;
You have to calculate the change between the two capture events, to get the period. Look at ex_capture.c, where this is shown.
