wireless
aaronik19
wireless
PostPosted: Sun Mar 29, 2015 7:11 am     Reply with quote
Dear friends do someone knows with a wireless module similar to HC-11 with AT Commands but using 2.4Ghz to have smaller antenna to be interfaced with pic 8-bit? The range of 200m is sufficient
PostPosted: Sun Mar 29, 2015 5:27 pm     Reply with quote
RFDIGITAL make quite a few, can easily get over 1Km with a coin cell battery.One of those you get what you pay for +-$100 a unit.
SherpaDoug
PostPosted: Sat Apr 04, 2015 6:09 am     Reply with quote
Could you use a WiFi module?
https://www.adafruit.com/products/1469
ronaldoklais
PostPosted: Sun Apr 05, 2015 4:10 pm     Reply with quote
ESP8266
Simple and low cost (3 USD <)
drolleman
PostPosted: Mon Apr 06, 2015 7:54 pm     Reply with quote
who sells it for less than $3?
aaronik19
PostPosted: Wed Apr 29, 2015 11:33 am     Reply with quote
Dear friends,
Thanks for your input. Regarding the suggestion offered for the ESP8266, can it be used to transfer data from one microcontroller to another which are spaced 50m standalone, since the description is WIFI module? What I need to make a wireless mesh network (hopping from one node to another). Last week I tested the HC-11 and strictly speaking did not give me the desired result....the signal was being lost after exceeding 20 meters.
