stepper motor
zeyad
stepper motor
PostPosted: Thu Feb 26, 2015 11:11 am     Reply with quote
i want to drive a stepper motor clock wise 200 steps using pic 16f877a . need help?
PostPosted: Thu Feb 26, 2015 11:18 am     Reply with quote
You'll ned to supply us with the motor specs, interface used between PIC and motor.
As a start, confirm your basic hardware by getting a '1Hz LED' program to run properly.
Check the examples folder...may be a 'stepper' program in there.
BTW the 877 is almost obsolete, I strongly suggest you buy a newer, cheaper more powerful PIC.
zeyad
stepper
PostPosted: Thu Feb 26, 2015 1:37 pm     Reply with quote
thank you jay .
zeyad
stepper
PostPosted: Thu Feb 26, 2015 1:58 pm     Reply with quote
jay the program in example is a bit complicated
PostPosted: Thu Feb 26, 2015 2:05 pm     Reply with quote
The key function is drive_stepper. Just drives four bits for a unipolar stepper, at a specified speed for a number of steps.
The code can't be much simpler, in fact any serious use of a stepper will be much more complex implementing acceleration and deceleration profiles etc.. However at slow speed this will work.
