ELCouz
| Increasing precision of Input Capture... |
Posted: Fri Feb 20, 2015 7:01 pm |
I've been reading and trying to modify the CCS example (ex_capture.c) to give me frequency instead of period lengths in uS.
However, i'm not very experienced with this kind of area.
I'm trying to read the frequency of a small flow meter (YF-S401)
The equation is according to the flow meters spec is:
Frequency: F = 98 * Q (Q is flow L / min) error: ± 5% 5880 pulse per liter of water
Frequency calculation = constant * unit flow (L / min) * time (seconds)
Flow Range :0.3-6L / min
I tried converting period to hz but I get garbage values every time...
printf("\r\r%1.9f Hz",(((float32)Time*64)/100000));
This what I've modified in the example but it's wrong.
I have a scope and the Freq range of the flow meter is 0 to 200 hz
Any clue? _________________ Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy! |
Joined: 01 Jul 2010 Posts: 9634 Location: Greensville,Ontario
Posted: Fri Feb 20, 2015 8:18 pm |
Are you using the sensor as the input for testing? If so, I wouldn't.
Instead, either use 1/2 wave and full wave line frequency (60Hz and 120Hz, here in Canada, eh !) as two test frequencies OR use a second PIC as the 'frequency generator' with say 25, 50, 100, 150, 200 Hz as outputs on 5 pins.
Simple delay_ms() should be good enough' for test loops.
This way you KNOW what the input is and can then pull your hair out 'getting the math' right.
hth
ELCouz
Posted: Fri Feb 20, 2015 8:33 pm |
| temtronic wrote: | Are you using the sensor as the input for testing? If so, I wouldn't.
Instead, either use 1/2 wave and full wave line frequency( 60Hz and 120Hz ,here in Canada,eh !) as two test frequencies OR use a second PIC as the 'frequency generator' with say 25,50,100,150,200 Hz as outputs on 5 pins.
hth
I see the value live on my scope and I can tell you it's not good
But I found out that it's better and easier just to count the pulses to know how many mL have passed thru!
Thanks! _________________ Regards,
Laurent
