CCP1 and CCP2 capture mode and timer
in_nursery
PostPosted: Tue Feb 03, 2015 1:11 pm     Reply with quote
Hi all
I use ccp1 and ccp2 in capture mode for getting the frequency of 2 signal and then to check the delay between this 2 signal. I use the timer 1.
It work fine.
I need more timer interrupt for parts of my software but as soon as I use "enable_interrupt" with another timer my software became completely buggy.
//Setup OSC
   setup_oscillator(OSC_4MHZ|OSC_INTRC);
//Setup ADC
      setup_adc_ports(CONFIG_ADC);
    setup_adc(ADC_CLOCK_DIV_8);
//Setup Timer 0
   setup_timer_0(RTCC_INTERNAL | RTCC_8_BIT| RTCC_DIV_128);
//Setup Timer 1 prescaler x1
      set_timer1(0);
//Setup Timer 3 prescaler x1
      set_timer3(65286);
      setup_timer_3(T3_INTERNAL | T3_DIV_BY_1);
   //enable_interrupts(INT_TIMER3);
//Setup CCP
      setup_ccp1(CCP_CAPTURE_RE); // Capture rise edge
      setup_ccp2(CCP_CAPTURE_RE);   // Capture rise edge
As soon as I
for having interrupts at 250us everything stop working fine.
thanks in advance for your help
PostPosted: Tue Feb 03, 2015 1:27 pm     Reply with quote
You don't show your interrupt handlers?.
If you enable any interrupt without a handler present, it'll crash the code.
Other thing is that you are showing presetting the timer3 to 65286. If you are doing a similar setting in the handler, then this interrupt would be happening every 100 instructions. Given that the interrupt handler alone will use about 60 instructions, it doesn't take much code in the interrupt routine to make the machine grind to a halt.
in_nursery
PostPosted: Tue Feb 03, 2015 1:35 pm     Reply with quote
Hi Ttelmah
here is my int3 Handler (work fine in other place)
#INT_TIMER3
void isr_timer3()
   set_timer3(65286);
      if (compteurTimer3 == 1)
         compteurTimer3 = 0;
      else {
         compteurTimer3 = 1;
         //if(compteurPeak > 0)
         //   compteurPeak--;
         // vérifier si un mot est terminé en déterminant si on a lu le dernier bit
         if(timerMotIR > 0) {
            timerMotIR--;
            // traiter l'interruption seulement si un mot IR est actuellement envoyé
            if (compteurBitIR > 1) { // ">1" car le dernier bit lu n'est pas un vrai bit
               // attendre 500us pour vérifier si bit est 1 ou 0
               if(timerBitIR > 0) {
                     timerBitIR--;
                 else { // délais de 500us terminé
                     // Déterminer si 1 ou 0
                     // Doit être fait une seule fois par bit
                     if (nouveauBitIR) {
                        motActuelIR <<= 1;
                        motActuelIR += input(PIN_IR);
                        nouveauBitIR = FALSE;   // éviter de traiter deux fois le même bit
                        compteurBitIR--;
         else {
            if (debounceIR == 0) {
            // Si on termine un mot
               if ((compteurBitIR < 13) && (vraiMotIR == 0)){
                     // Vérifier si le mot qui vient d'être lu est identique au précédent
                     if(motActuelIR == motAncienIR) { // oui
                        compteurBonMotIR++;
                     else {                           // non
                        //vraiMotIR = motActuelIR;
                        compteurBonMotIR = 0;
                     // S'assurer d'avoir lu le même mot 3 fois avant de conclure que c'est
                     // le bon mot.
                     if(compteurBonMotIR > 2) {
                        vraiMotIR = motAncienIR;
                        debounceIR = TEMPS_DEBOUNCE_IR;
                        //   compteurVeille = TEMPS_VEILLE;   // Nouveau IR CMS
                        motAncienIR = 0;
                        motActuelIR = 0;
                     motAncienIR = motActuelIR;
                     // Initialiser le compteur de bits.
                     // On utilise 13 car une interruption est générée après le 12e bit.
                     compteurBitIR = 13;
                     motActuelIR = 0;     //initialiser le mot
            else {
               motAncienIR = 0;
               motActuelIR = 0;
and the setup
