just first adc sample is not good
id31
PostPosted: Wed Jan 21, 2015 1:37 am     Reply with quote
hello all
I will be happy if someone could answer my question, sorry about my english by the way Smile
I am using pic16 and doing adc sample. The problem is that just the first sample is 0..... the 4 other after are ok. Does somebody have an idea?
By the way when i call the function again the first sample is ok..so i get 5 good samples.
int i=0;
unsigned int32 Sum=0;
setup_adc(adc_clock_internal);
delay_ms(1);
setup_adc_channel(3);
delay_ms(1);
for(i=0;i<5;i++)
 SUM+=read_adc();
 delay_ms(10);
return sum/5
appreciate your help. good day
PostPosted: Wed Jan 21, 2015 8:42 am     Reply with quote
1) The code as posted doesn't show us the setup, or PIC you are. Code should be a small complete program that we can compile. Not a 'snippet'.
2) The clock is almost certainly not recommended. The internal RC clock for the ADC should normally (on most PIC16's) only be used if you are running below 1MHz, or are putting the chip to sleep for the ADC sample.
3) Then the code as posted won't work. You are not telling the multiplexer which channels are to be used for ADC operation. The commands being used are not the normal CCS ones (you are using CCS?....).
PostPosted: Wed Jan 21, 2015 3:20 pm     Reply with quote
another 'thing'
/5 is 'bad' on a PIC, consumes a LOT of time and resources.
better to use /4 or /8
way faster, only 1-2 intrsuctions !
jay
PostPosted: Wed Jan 21, 2015 3:38 pm     Reply with quote
MicroC uses 'setup_adc_channel'. Suspicion that it is not CCS code, rises....
