Wake up from Sleep()
soonc
PostPosted: Wed Jan 14, 2015 2:29 pm     Reply with quote
Planning to use a PIC18F26K22 and I need to put the chip to sleep for power saving.
I have the main interrupt available just for this purpose (Pin_B0).
I intend to issue a command for the chip to execute the Sleep() and the external circuity will do the wake up interrupt on Pin_B0.
Pseudo Code:
int a=0;
switch(Command)
  case 'S': // go to sleep command
     Sleep();
      a=1;  //next line of code after sleep
When the interrupt occurs will the chip execute the next line of code after the Sleep() when it wakes up ?
If the next line is executed should I delay_ms(100 or so) to give the chip time to wake up ?
If not what happens after the chip wakes up ?
Is the stack preserved as it was prior to the Sleep() call ?
Thanks for advice.
PostPosted: Wed Jan 14, 2015 3:47 pm     Reply with quote
You need to put a NOP instruction as the next instruction (delay_cycles(1);). The instruction after, is 'prefetched' when you go to sleep. If it is one half of something like a memory data movement, this can cause problems. Hence you are advised to always ensure this instruction effectively does nothing. The single 'delay_cycles' instruction codes as a NOP. A longer delay won't.
Everything will then continue as normal. Stack, RAM etc., are all preserved.
Depending on your clock source, you should wait for the oscillator to re-stabilise. Check the status from the oscillator if it is something like a crystal.
soonc
PostPosted: Wed Jan 14, 2015 7:59 pm     Reply with quote
Thanks for the advice. Sleep() is something I have never used.
