th3gr8
| Parallel Printer interfacing !! |
Posted: Wed Jan 07, 2015 8:10 am |
Hello All ..
I want to interface a parallel printer with my PIC16F877A (serial printers are not available) .. I googled and found out that i need to connect D0-D7 with any output port of the PIC and need to connect strobe and busy Pin .. Now i am confused about making its code and circuit. I want to know that by directly connecting these pins with my printer, will i be able to print something or do i need any circuit in between them?
and If someone has an example Code and circuit, plz share it ..
Also, can i make it with USB-to-serial interface for a printer having USB port?? _________________ A learner |
Posted: Wed Jan 07, 2015 8:27 am |
Sequence is:
Read the BUSY pin. Wait till it goes off.
Write ASCII character to D0 to D7 (just output it).
Turn the STB line on, then off.
Loop back to start, till all characters are sent.
It depends massively on your printer. The basic transmission is the same for all, but simple (old) printers are relatively 'smart', and you only need to send standard text and control characters (line feed, carriage return etc..). A lot of the later 'cheap' printers are completely dumb, and rely on being sent 'raw' binary data, to control the bit patterns on the heads. They relied completely on all the 'work' of generating characters being done in the PC. Too much data for any but the largest PIC's, and completely 'custom' to the particular make of printer.
An interface to a USB printer, would be complex. Most cheap ones do rely on the computer to do all the work, and you would need to implement a USB host. Simplest way (if the printer is not too dumb), is to use an FTDI Vinculum to provide the host. Again if the printer needs anything beyond basic text, serial would have speed issues. |
Posted: Wed Jan 07, 2015 7:33 pm |
What Mr. T says is right....very simple code and will hookup to printer directly. I did the same using a 16F84 some years ago.....to allow a serial port from a client's computer to use a parallel port printer.
If your computer sends data slower than the printer prints , you do not need to 'buffer' the data.
hth
jay |
th3gr8
Posted: Wed Jan 07, 2015 9:43 pm |
and if i use a Thermal Printer (with Parallel Port), will the sequence of writing the data be same? _________________ A learner |
gpsmikey
Posted: Wed Jan 07, 2015 10:58 pm |
If it is a parallel port, the interface should be the same. The printer may need extra processing for graphics or whatever, but the interface you are talking about from a hardware viewpoint is called the "centronics interface" - see here for additional information and links for the interface and timing.
http://en.wikipedia.org/wiki/IEEE_1284
mikey _________________ mikey
th3gr8
Posted: Thu Jan 08, 2015 1:33 am |
Ok .. but i read somewhere that Centronics interface was used on Old printers etc .. And if i connected the printer with PIC, how much XTAL value would i need? can i work with 4Mhz?? is crystal value very much critical? _________________ A learner |
Posted: Thu Jan 08, 2015 2:04 am |
The parallel printer interface is the Centronics interface. something like 99% of modern PC printers use USB instead. Hence the comment about 'old printers'. There are quite a lot of 'specialist' printers that still use the Centronics interface, just not in the mainstream PC world.
It depends how fast you want to send the data, and how much data you have to send, together with how fast the printer you are talking to is?. Many of the little thermal units can only accept a few hundred characters per second, and this a chip at 4MHz should be able to handle easily. However if you talk to something like a laser printer, and then start sending graphics, rates more like half a million characters per second can be involved to feed the machine properly. |
th3gr8
Posted: Thu Jan 08, 2015 3:43 am |
Ok.. That helps ..
so now, i want use 10 i/o pins of my PIC and follow the sequence.. do i need to put a resistor on the Data lines (D0-D7) or should i connect it directly?
Sorry for asking such silly questions :( .. _________________ A learner |
Posted: Thu Jan 08, 2015 5:17 am |
For short connections you don't need anything on the data lines. What you do need is a resistor to pull the 'busy' line to the 'busy' state, if the connection is not present. This way the code won't try to send to the printer if it is not there.
On longer cables you'll commonly find termination to help prevent signal 'ringing' at high data rates. |
th3gr8
Posted: Thu Jan 08, 2015 7:23 am |
| Ttelmah wrote: | For short connections you don't need anything on the data lines. What you do need is a resistor to pull the 'busy' line to the 'busy' state, if the connection is not present. This way the code won't try to send to the printer if it is not there.
Ok, so a resistor on the Busy Pin ..
Let me try to implement the hardware .. _________________ A learner |
Posted: Thu Jan 08, 2015 9:18 am |
Here's something that worked a few years ago, just needs minor changes to run on 16F877
// serialpt.c
// serial to parallel printer chip
// allows EVE to use parallel printers
#device PIC16F84
#include "16F84.H"
#fuses XT,NOWDT,NOPROTECT,PUT // options
#use delay(clock=4000000) // xtal
#use rs232(baud=2400,xmit=PIN_A4,rcv=PIN_A3) // rs232 setup
#zero_ram // fresh start
#use fast_io(a) // direct access
#use fast_io(b) // of ports
#byte PORTA = 5
#byte PORTB = 6
#define low 0;
#define high 1;
#define off 0;
#define on 1;
#define PC_Flow PIN_A0 //
#define LPT_Busy PIN_A1 //
#define LPT_!Strobe PIN_A2 //
#define PC_Serial PIN_A3 //
#define Not_Used PIN_A4 //
#define LPT_D0 PIN_B0 //
#define LPT_D1 PIN_B1 //
#define LPT_D2 PIN_B2 //
#define LPT_D3 PIN_B3 //
#define LPT_D4 PIN_B4 //
#define LPT_D5 PIN_B5 //
#define LPT_D6 PIN_B6 //
#define LPT_D7 PIN_B7 //
void Init_PIC()
set_tris_a(0b00010); // as required
set_tris_b(0b00000000); // all outputs
port_b_pullups(FALSE); //
PORTA = 0b00100; // strobe set hi !
PORTB = 0b00000000; // all low(off)
delay_us(10); // dly a bit...
main() {
int c; // c is an integer(8 bits)
Init_PIC(); // initialize PIC
while(true) { // endless loop
c=GETC(); //wait for a character to come in
PORTB=c; // send to PORTB ( lpt)
delay_us(2); // dly to steady lpt data lines
OUTPUT_LOW(PIN_A2); // high-low-high !!
delay_us(2); // actual -strobe pulse
output_high(PIN_A2); // reset to high( idle state)
} // endless loop
} // end of main
It should give you a good start for your project....PM any questions....
Posted: Thu Jan 08, 2015 9:47 am |
| If you look at the code, he was using 2400bps, and this was so slow, that Temtronic doesn't even bother about 'busy', being able to assume the printer can always take the next character. Need to think about this if data is arriving faster.... |
Posted: Thu Jan 08, 2015 10:12 am |
yup, 2400 baud was what the client's 68K machine's serial port was configured for. I looked at the file...yeesh 10 YEARS ago, time flies.Actual computer($100K when new) was scrapped last year...sigh...
Since most(all) printers have a large 'buffer', handshaking wasn't needed back then.Data from the EVE was less than 500 bytes.
The code as written should be a good start, easy to test(it did work for almost 10 years), easy to modify as required.
Ideally use the 877's hardware UART, CCS's ISR for buffering and a 20MHz xtal.....ideas...
gpsmikey
Posted: Thu Jan 08, 2015 11:31 am |
The actual crystal value is not very critical for the centronics (parallel) interface because it uses the strobe/busy handshake to move data so the crystal frequency is not very critical there (other than lower crystal frequencies mean the processor runs slower). Where the crystal frequency is critical is if you are using the serial port (uart). There, the baud rate is important and it is derived from the crystal so you need to address that issue if you are using the serial port.
th3gr8
Posted: Fri Jan 09, 2015 6:17 am |
| gpsmikey wrote: | The actual crystal value is not very critical for the centronics (parallel) interface because it uses the strobe/busy handshake to move data so the crystal frequency is not very critical there (other than lower crystal frequencies mean the processor runs slower). Where the crystal frequency is critical is if you are using the serial port (uart). There, the baud rate is important and it is derived from the crystal so you need to address that issue if you are using the serial port.
mikey |
Luckily i've got a Serial thermal printer now .. Please tell me the crystal value's issue .. and also tell me that what Pins i need other than TX and RX .. I think that RTS and CTS pins will also play an important role or can i simply ignore them and use only TX and RX??
Plz guide me _________________ A learner |
