Program Build Failed
SSURESHREDDY
PostPosted: Thu Dec 04, 2014 6:01 am     Reply with quote
Hi All,
I am working with PIC 1938 and C compiler V4.114.
I successfully verified my code up %39 of ROM, after that even if I included a single statement it is not successfully building.
I have seen this type of problem when ROM is full, but I never saw this problem even if I am not wrote %40 of program.
Please anybody help me to solve this problem...
Executing: "C:\Program Files (x86)\PICC\Ccsc.exe" +FM "main.c" +DF +LN +T +A +M +Z +Y=9 +EA #__16F1938=TRUE
>>> Warning 216 "main.c" Line 741(48,49): Interrupts disabled during call to prevent re-entrancy: (@FLT)
>>> Warning 202 "main.c" Line 221(26,50): Variable never used: EEPROM_Write_Enable_flag
>>> Warning 202 "main.c" Line 227(22,42): Variable never used: Charger_Current_flag
>>> Warning 202 "main.c" Line 250(15,29): Variable never used: Old_Array_KWAH
>>> Warning 202 "main.c" Line 251(18,35): Variable never used: Old_AC_Charger_KW
>>> Warning 202 "main.c" Line 252(20,39): Variable never used: Old_AC_Charger_KWAH
>>> Warning 202 "main.c" Line 259(15,29): Variable never used: AC_Charger_KWH
>>> Warning 202 "main.c" Line 260(14,27): Variable never used: AC_Charger_KW
*** Error 71 "main.c" Line 741(48,49): Out of ROM, A segment or the program is too large DISPLAY_PARAMETERS
Seg 00021-007FF, 00F5 left, need 073F
Seg 00800-00FFF, 0800 left, need 080F
Seg 01000-017FF, 0800 left, need 080F
Seg 01800-01FFF, 0800 left, need 080F
Seg 02000-027FF, 0800 left, need 080F
Seg 02800-02FFF, 0800 left, need 080F
Seg 03000-037FF, 0800 left, need 080F
Seg 03800-03FFF, 0800 left, need 080F
Seg 00000-00002, 0000 left, need 080F
Seg 00003-00003, 0001 left, need 080F
Seg 00004-00020, 0000 left, need 080F
Seg 00021-007FF, 00F5 left, need 080F
1 Errors, 8 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Thu Dec 04 17:09:40 2014
PostPosted: Thu Dec 04, 2014 6:53 am     Reply with quote
classic error....
It's telling you that your code is too large to fit into the memory.
IE: One 'function' or 'piece' of your code needs 073F bytes of space yet there's only 00F5 left in a memory page.
While physically the PIC still has a lot of memory left, you have to ensure that 'functions' reside 100% within a memory 'page'.You cannot 'cross' page boundaries.
The 'cure' is to rewrite code to have smaller functions,sometimes rearranging the order will get the code to fit as well.
consider a PIC with 1000 bytes of code space, consisting of two 'page' each 500 bytes long and 4 functions A-100 bytes, B 200 bytes, C 300 Bytes, and D 400 bytes.
If coded A-B-C-D, then the compiler halts after B, since it knows it can't get 100+200+300 bytes into a 500 byte 'page'
However if you 'recode'( rearrange the sequence) to A-D-B-C, then it will compile as A(100) + D(400) = 500 , and B(200)+C(300)= 500.
hth
jay
RF_Developer
PostPosted: Thu Dec 04, 2014 7:42 am     Reply with quote
By the way, the warnings are telling you important stuff too.
This shows you are using floating point in an ISR, possibly just a cast to float, as well as the main code. Floating point is never a great idea in ISRs as it takes a long time to process.
The other warnings:
tell you that you have declared some variables that you haven't used. If they are not for something you haven't added yet they are probably redundant. I think the compiler doesn't even allocate RAM for such variables, so there's probably not RAM wasted.
SSURESHREDDY
PostPosted: Thu Dec 04, 2014 8:00 am     Reply with quote
Yeah...
I got it.
I just split my large function into two functions, now problem is fixed.
Thanks Jay
Still I am writing the code, is there any chance to come again this problem..
SURESH
PostPosted: Thu Dec 04, 2014 9:22 am     Reply with quote
yes...
If you use a 'chunk of code' several times throughout your main program, consider creating it as a 'function', thus callable from anywhere. That way you'll save space and may not see the error again.
hth
jay
