1. I've loaded the bootloader into the PIC.
2. I've hooked up the serial input/output tool via RS232
3. I've successfully powered-up the PIC with bootload PIN active which results in message on screen saying 'waiting for download'.
4. I've downloaded a simple flashing LED program
5. Powered-up the board again.
Result - LED not flashing so didn't work
Fuses are matched in both files.
It's a CCS CAN bus dev board so the hardware is all ok.
Compiler version PCWH 5.017
Not sure what I'm doing wrong at the moment.
Any assistance would be appreciated.
Posted: Thu Dec 04, 2014 8:06 am
Remember you need to build the program to be loadable. You can just build a program and load it.
Look at ex_bootload.c, which shows how a program that is to be loaded needs to be built.
jmaudley
Working
Posted: Thu Dec 04, 2014 8:26 am
Missed BOOTLOADER.H
Thank you.
Posted: Thu Dec 04, 2014 9:11 am
Good.
Nice things was your description was nice and clear so this seemed the obvious problem.
